Introduction
Use this guide to replace the CPU in a Dell Inspiron 1525.
Outils
Pièces
Aucune pièce nécessaire.
Remove/loosen the eight 4.80 mm Phillips #1 screws securing the bottom panel.
The screws may only need to be loosened, as they are generally retained by plastic washers.
Remove the bottom panel.
Loosen the five #1 Phillips screws securing the heat sink and clean it with compressed air
Gently lift the heat sink from side indicated in the picture.
Use a small flathead screwdriver to turn the ZIF-socket cam screw counterclockwise until it can't be turned anymore.
Lift the CPU out of its socket, being careful not to bend its pins.
Annulation : je n'ai pas terminé ce guide.
3 autre(s) ont terminé cette réparation.
