Introduction
Use this guide to help you replace the Wireless Mini-Card in a Dell Inspiron 1525.
Ce dont vous avez besoin
Remove/loosen the eight 4.80 mm Phillips #1 screws securing the bottom panel.
The screws may only need to be loosened, as they are generally retained by plastic washers.
Remove the bottom panel.
Use the flat end of a spudger to gently pry the black and white antenna connectors off the Wireless Mini-Card.
3 autres ont terminé cette réparation.
