Aller au contenu principal
Dell Inspiron 1526 Keyboard Replacement
Ce dont vous avez besoin
  1. Dell Inspiron 1526 Keyboard Replacement, Battery: étape 1, image 1 de 3 Dell Inspiron 1526 Keyboard Replacement, Battery: étape 1, image 2 de 3 Dell Inspiron 1526 Keyboard Replacement, Battery: étape 1, image 3 de 3
    • Slide the unlock button to the left to release the battery.
    • Slide the battery away from the laptop to remove.
    • The unlock button is located on the bottom of the laptop.
  2. Dell Inspiron 1526 Keyboard Replacement, Keyboard: étape 2, image 1 de 1
    • Loosen the two 3.5mm Phillips #1 screws in the battery bay.
  3. Dell Inspiron 1526 Keyboard Replacement: étape 3, image 1 de 1
    • Flip the laptop over.
    • Lift the control cover by prying the right side of the cover with an iFixit opening tool.
  4. Dell Inspiron 1526 Keyboard Replacement: étape 4, image 1 de 1
    • Carefully lift the control cover up and forward to reveal a single ribbon cable.
  5. Dell Inspiron 1526 Keyboard Replacement: étape 5, image 1 de 1
    Outil utilisé dans cette étape :
    • Use tweezers to squeeze the tabs on the connector and remove the ribbon cable.
  6. Dell Inspiron 1526 Keyboard Replacement: étape 6, image 1 de 2 Dell Inspiron 1526 Keyboard Replacement: étape 6, image 2 de 2
    • Remove the control cover.
  7. Dell Inspiron 1526 Keyboard Replacement: étape 7, image 1 de 1
    • Remove the two 3mm Phillips #1 screws at the top of the keyboard where the control cover was.
  8. Dell Inspiron 1526 Keyboard Replacement: étape 8, image 1 de 1
    • Lift the keyboard gently from the top, but do not remove completely.
    • Looking under the keyboard, towards the touch-pad in the center, lift up the black tab on the connector with tweezers for the keyboard ribbon cable.
  9. Dell Inspiron 1526 Keyboard Replacement: étape 9, image 1 de 2 Dell Inspiron 1526 Keyboard Replacement: étape 9, image 2 de 2
    • Remove the keyboard.
Joshua Busick
Membre depuis le 09/17/19
291 Réputation
2 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 21
30 derniers jours : 32
Total : 185
