Aller au contenu principal
Dell Inspiron 1545 RAM Replacement
Ce dont vous avez besoin
  1. Dell Inspiron 1545 RAM Replacement, Battery: étape 1, image 1 de 1
    • Before attempting to remove the battery ensure that the laptop is disconnected from all power sources and turned off.
    • Turn the laptop over to its back.
  2. Dell Inspiron 1545 RAM Replacement: étape 2, image 1 de 1
    • Slide the release latch while simultaneously pulling backwards on the battery.
  3. Dell Inspiron 1545 RAM Replacement: étape 3, image 1 de 1
    • Slide the battery out of the battery bay.
  4. Dell Inspiron 1545 RAM Replacement, Base Cover: étape 4, image 1 de 1
    • Unscrew the four screws (3mm Phillips #1) that hold the base cover in place.
    • The top 3 screws are "captive" (held in by a retaining ring) and will not come out.
  5. Dell Inspiron 1545 RAM Replacement: étape 5, image 1 de 2 Dell Inspiron 1545 RAM Replacement: étape 5, image 2 de 2
    • Carefully lift the base cover vertically away from the laptop.
  6. Dell Inspiron 1545 RAM Replacement, RAM: étape 6, image 1 de 1
    • Spread apart the securing clips on each end of the memory stick until the memory stick pops up.
    • Remove the memory stick from the laptop.
    • Repeat these steps to remove the second memory stick.
9 autres ont terminé cette réparation.
Nathan Lemay
Membre depuis le 04/16/14
3 064 Réputation
15 tutoriels rédigés
Équipe
Cal Poly, Team 9-14, Regan Spring 2014 Membre de l'équipe Cal Poly, Team 9-14, Regan Spring 2014
CPSU-REGAN-S14S9G14
4 membres
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 5
30 derniers jours : 28
Total : 2,943
