Introduction
In this guide, we will be showing you how to remove and replace the Display Assembly.
Pièces
Aucune pièce nécessaire.
WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the procedures in Before You Begin.
  • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the procedures in Before You Begin.
  • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface.
  • Note of the routing of the Mini-Card antenna cables and remove them from the routing guides on the bottom of the computer.
Ajouter un commentaire
Remove the two screws on the bottom of the computer that secure the display assembly to the computer base.
  • Remove the two screws on the bottom of the computer that secure the display assembly to the computer base.
  • Pull the Mini-Card antenna cables up through the slot in the computer base.
  • Note the routing of the Mini-Card antenna cables and remove them from the routing guides on the palm rest.
  • Disconnect the display cable from the connector on the system board, and remove the display cable grounding screw.
  • Hold the display assembly in place and remove the three screws that secure the display assembly to the computer base.
  • Lift the display assembly off the alignment posts on the computer base.
  • Use the alignment posts to place the display assembly on the computer base.
  • Replace the three screws that secure the display assembly to the computer base
  • Connect the display cable to the connector on the system board, and replace the display cable grounding screw.
  • Route the Mini-Card antenna cables through the routing guides on the palm rest.
  • Thread the Mini-Card antenna cables through the slot in the computer base.
  • Turn the computer over and replace the two screws that secure the display assembly to the computer base.
Ligne d'arrivée
Terrence15
Membre depuis le 18/12/2017
69 301 Réputation
444 tutoriels rédigés
Équipe
Informative Technologies Inc. Membre de l'équipe Informative Technologies Inc.
Community
15 membres
917 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 11
Total : 39
