Aller au contenu principal
Dell Inspiron 1564 Hard Drive Replacement
Ce dont vous avez besoin
  1. Dell Inspiron 1564 Hard Drive Replacement, Remove Battery: étape 1, image 1 de 2 Dell Inspiron 1564 Hard Drive Replacement, Remove Battery: étape 1, image 2 de 2
    • Locate battery latch on bottom of computer and slide to right.
    • While holding battery latch, pull the battery away from device and the battery will come free.
  2. Dell Inspiron 1564 Hard Drive Replacement, Remove Bottom Cover Screws: étape 2, image 1 de 1
    • With a J0 screwdriver bit, loosen all screws from the backing above the battery latch and remove the covering.
  3. Dell Inspiron 1564 Hard Drive Replacement, Hard Drive Removal: étape 3, image 1 de 2 Dell Inspiron 1564 Hard Drive Replacement, Hard Drive Removal: étape 3, image 2 de 2
    • Locate the three 4mm screws securing the hard drive and unscrew them with a J0 screwdriver.
    • Slide the hard drive to the left to unplug the SATA data and SATA power cables, then gently pry upwards and pull the drive away from device.
Megan Nelson
Membre depuis le 10/05/15
296 Réputation
2 tutoriels rédigés
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 12
30 derniers jours : 29
Total : 2,016
