Aller au contenu principal
Dell Inspiron 1564 Memory Module Replacement
  1. Dell Inspiron 1564 Memory Module Replacement, Popping up the Memory Module: étape 1, image 1 de 2 Dell Inspiron 1564 Memory Module Replacement, Popping up the Memory Module: étape 1, image 2 de 2
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the procedures in Before You Begin.
    • CAUTION: To prevent damage to the memory module connector, do not use tools to spread the memory module securing clips.
    • Use your fingertips to carefully spread apart the securing clips on each end of the memory module connector until the memory module pops up.
  2. Dell Inspiron 1564 Memory Module Replacement, Remove the Memory Module: étape 2, image 1 de 1
    • Remove the memory module from the memory module connector.
  3. Dell Inspiron 1564 Memory Module Replacement, Align the Notch: étape 3, image 1 de 1
    • Align the notch in the memory module with the tab in the memory module connector.
  4. Dell Inspiron 1564 Memory Module Replacement, Sliding the Memory Module: étape 4, image 1 de 1
    • Slide the memory module firmly into the slot at a 45-degree angle, and press the memory module down until it clicks into place. If you do not hear the click, remove the memory module and reinstall it.
    • NOTE: If the memory module is not installed properly, the computer may not boot.
Ligne d'arrivée
Terrence15
Membre depuis le 12/18/17
79 549 Réputation
441 tutoriels rédigés
Équipe
RampUP America, Inc. Membre de l'équipe RampUP America, Inc.
Community
43 membres
1 985 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 3
30 derniers jours : 6
Total : 268
