Aller au contenu principal
Dell Inspiron 15R 5520 Display Replacement
Ce dont vous avez besoin
  1. Dell Inspiron 15R 5520 Display Replacement, Battery: étape 1, image 1 de 1
    • We are removing the battery to avoid the possibility of an electrical discharge when working with this system.
    • Flip device on its back displaying the battery.
  2. Dell Inspiron 15R 5520 Display Replacement: étape 2, image 1 de 3 Dell Inspiron 15R 5520 Display Replacement: étape 2, image 2 de 3 Dell Inspiron 15R 5520 Display Replacement: étape 2, image 3 de 3
    • Place a finger on both latches and push outwards.
    • Grab by the lip and pull upwards to remove battery.
  3. Dell Inspiron 15R 5520 Display Replacement, Display: étape 3, image 1 de 3 Dell Inspiron 15R 5520 Display Replacement, Display: étape 3, image 2 de 3 Dell Inspiron 15R 5520 Display Replacement, Display: étape 3, image 3 de 3
    • Lay the device as shown on table.
    • Use the plastic opening tool to separate the plastic casing on all sides.
  4. Dell Inspiron 15R 5520 Display Replacement: étape 4, image 1 de 2 Dell Inspiron 15R 5520 Display Replacement: étape 4, image 2 de 2
    • Remove casing for screen.
  5. Dell Inspiron 15R 5520 Display Replacement: étape 5, image 1 de 3 Dell Inspiron 15R 5520 Display Replacement: étape 5, image 2 de 3 Dell Inspiron 15R 5520 Display Replacement: étape 5, image 3 de 3
    • Locate and remove the top two 4mm screws.
  6. Dell Inspiron 15R 5520 Display Replacement: étape 6, image 1 de 3 Dell Inspiron 15R 5520 Display Replacement: étape 6, image 2 de 3 Dell Inspiron 15R 5520 Display Replacement: étape 6, image 3 de 3
    • Locate and remove the three 3mm left hand side screws.
  7. Dell Inspiron 15R 5520 Display Replacement: étape 7, image 1 de 3 Dell Inspiron 15R 5520 Display Replacement: étape 7, image 2 de 3 Dell Inspiron 15R 5520 Display Replacement: étape 7, image 3 de 3
    • Locate and remove the three 3mm right hand side screws.
  8. Dell Inspiron 15R 5520 Display Replacement: étape 8, image 1 de 3 Dell Inspiron 15R 5520 Display Replacement: étape 8, image 2 de 3 Dell Inspiron 15R 5520 Display Replacement: étape 8, image 3 de 3
    • Lift the display up to reveal the cable behind it.
    • Pull the cable straight down.
  9. Dell Inspiron 15R 5520 Display Replacement: étape 9, image 1 de 3 Dell Inspiron 15R 5520 Display Replacement: étape 9, image 2 de 3 Dell Inspiron 15R 5520 Display Replacement: étape 9, image 3 de 3
    • Sit the device upright and lay the display down on the keyboard.
    • Locate the cable on the base of the display.
    • Pull gently away from yourself.
  10. Dell Inspiron 15R 5520 Display Replacement: étape 10, image 1 de 1
    • Remove screen.
5 autres ont terminé cette réparation.
zAj
Membre depuis le 09/15/16
484 Réputation
2 tutoriels rédigés
Équipe
USF Tampa, Team 18-1, Blackwell Fall 2016 Membre de l'équipe USF Tampa, Team 18-1, Blackwell Fall 2016
USFT-BLACKWELL-F16S18G1
3 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 13
30 derniers jours : 25
Total : 2,737
