Aller au contenu principal
Dell Inspiron 15z 5523 Memory Module Replacement
Ce dont vous avez besoin
  1. Dell Inspiron 15z 5523 Memory Module Replacement, Loosen the Screw: étape 1, image 1 de 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in "Before You Begin".
    • Close the display and turn the computer over.
    • Loosen the captive screw that secures the memory-module cover to the computer base.
  2. Dell Inspiron 15z 5523 Memory Module Replacement, Lifting the Module Cover: étape 2, image 1 de 1
    • Using your fingertips, lift the memory-module cover out of the slots on the computer base.
  3. Dell Inspiron 15z 5523 Memory Module Replacement, Popping up the Memory Module: étape 3, image 1 de 1
    • Use your fingertips to carefully spread apart the securing clips on each end of the memory-module connector until the memory module pops up.
    • Align the notch on the NEW memory module with the tab on the memory-module connector.
  4. Dell Inspiron 15z 5523 Memory Module Replacement, Sliding the Memory Module: étape 5, image 1 de 1
    • Slide the memory module firmly into the connector at a 45-degree angle and press the memory module down until it clicks into place.
    • NOTE: If you do not hear the click, remove the memory module and reinstall it.
  5. Dell Inspiron 15z 5523 Memory Module Replacement, Slide the Tabs: étape 6, image 1 de 1
    • Slide the tabs on the memory-module cover into the slots on the computer base and snap the memory-module cover into place.
  6. Dell Inspiron 15z 5523 Memory Module Replacement, Tighten the Screw: étape 7, image 1 de 1
    • Tighten the captive screw that secures the memory-module cover to the computer base.
Ligne d'arrivée
Terrence15
Membre depuis le 12/18/17
79 522 Réputation
441 tutoriels rédigés
Équipe
RampUP America, Inc. Membre de l'équipe RampUP America, Inc.
Community
43 membres
1 985 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 2
Total : 196
