Aller au contenu principal
Dell Inspiron 16-7620 RAM Replacement
Ce dont vous avez besoin
  1. Dell Inspiron 16-7620 RAM Replacement, RAM: étape 1, image 1 de 3 Dell Inspiron 16-7620 RAM Replacement, RAM: étape 1, image 2 de 3 Dell Inspiron 16-7620 RAM Replacement, RAM: étape 1, image 3 de 3
    • Using a Phillips #00 screwdriver, fully unscrew all seven 5 mm screws circled in red.
    • Using the same screwdriver, unscrew the two 5 mm screws circled in orange until the back of the laptop begins to pop off.
    • Keep in mind should not be fully removed; they are captive screws.
    • Starting near the hinges of the laptop, use a jimmy to work around the laptop, carefully prying the back off.
  2. Dell Inspiron 16-7620 RAM Replacement: étape 2, image 1 de 3 Dell Inspiron 16-7620 RAM Replacement: étape 2, image 2 de 3 Dell Inspiron 16-7620 RAM Replacement: étape 2, image 3 de 3
    • Lift up the black covers outlined in red to reveal the RAM module(s).
    • Gently push the two metal arms outwards to release the RAM module.
    • The RAM should pop out of its socket when you release the second tab.
  3. Dell Inspiron 16-7620 RAM Replacement: étape 3, image 1 de 2 Dell Inspiron 16-7620 RAM Replacement: étape 3, image 2 de 2
    • Remove the RAM by sliding outwards.
Lucian Chauvin
Membre depuis le 06/28/23
97 Réputation
1 tutoriel rédigé
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 6
30 derniers jours : 31
Total : 282
