Aller au contenu principal
Dell Inspiron 17-3721 Fan Replacement
Ce dont vous avez besoin
  1. Dell Inspiron 17-3721 Fan Replacement, Keyboard: étape 1, image 1 de 2 Dell Inspiron 17-3721 Fan Replacement, Keyboard: étape 1, image 2 de 2
    • Use a plastic opening tool or a metal spudger to pry out the tabs on top of the keyboard.
    • After prying the tabs up, carefully pull the keyboard out of the laptop.
    • Use caution when prying the tabs up or lifting the keyboard up, as the plastic material and the strip on the keyboard can easily break.
  2. Dell Inspiron 17-3721 Fan Replacement: étape 2, image 1 de 2 Dell Inspiron 17-3721 Fan Replacement: étape 2, image 2 de 2
    • Once the keyboard is lifted, locate the release tab.
    • Using a plastic opening tool or your finger, lift the tab so that it opens .
    • Once the tab is open, the strip on the keyboard can be removed.
  3. Dell Inspiron 17-3721 Fan Replacement, Optical Drive: étape 3, image 1 de 3 Dell Inspiron 17-3721 Fan Replacement, Optical Drive: étape 3, image 2 de 3 Dell Inspiron 17-3721 Fan Replacement, Optical Drive: étape 3, image 3 de 3
    • Remove the four 6 mm PH1 Philips head screws under the keyboard.
    • Carefully pop off the cover using the plastic opening tools and your hands.
  4. Dell Inspiron 17-3721 Fan Replacement: étape 4, image 1 de 3 Dell Inspiron 17-3721 Fan Replacement: étape 4, image 2 de 3 Dell Inspiron 17-3721 Fan Replacement: étape 4, image 3 de 3
    • Remove the 4 mm PH1 Philips head screw holding down the optical drive.
    • Use your hand to slide the drive out of the device.
  5. Dell Inspiron 17-3721 Fan Replacement, Fan: étape 5, image 1 de 1
    • Remove the seven 6mm PH1 Philips head screws from the motherboard.
    • There may be more or less screws in your motherboard as the laptops do vary.
  6. Dell Inspiron 17-3721 Fan Replacement: étape 6, image 1 de 2 Dell Inspiron 17-3721 Fan Replacement: étape 6, image 2 de 2
    • Located on the lower left of the motherboard, disconnect the wire that connects the speaker by pushing it or pulling it away from the white box.
  7. Dell Inspiron 17-3721 Fan Replacement: étape 7, image 1 de 1
    • Located on the lower right of the motherboard, flip up the black hatch and remove the ribbon cable by gently tugging it outwards.
    • Ribbon cables are very fragile and can tear easily. Handle with care.
  8. Dell Inspiron 17-3721 Fan Replacement: étape 8, image 1 de 1
    • Remove the 4mm PH1 Philips screw to the right of the fan.
  9. Dell Inspiron 17-3721 Fan Replacement: étape 9, image 1 de 1
    • Remove the 4mm PH1 Philips screw to the top of the fan.
  10. Dell Inspiron 17-3721 Fan Replacement: étape 10, image 1 de 1
    • Remove the motherboard from the USB sockets to the left by first pulling the motherboard to the right and then flip the motherboard up against the screen.
  11. Dell Inspiron 17-3721 Fan Replacement: étape 11, image 1 de 1
    • Located on the lower left, remove the 4mm PH1 Philips screw to the top of the fan.
  12. Dell Inspiron 17-3721 Fan Replacement: étape 12, image 1 de 2 Dell Inspiron 17-3721 Fan Replacement: étape 12, image 2 de 2
    • Remove the wire for the fan by pulling or pushing the white tab from the white box.
Kevin Prairie
Membre depuis le 03/20/18
445 Réputation
4 tutoriels rédigés
Équipe
UMass Dartmouth, Team S5-G3, Peak Spring 2018 Membre de l'équipe UMass Dartmouth, Team S5-G3, Peak Spring 2018
UMASSD-PEAK-S18S5G3
3 membres
7 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 13
30 derniers jours : 25
Total : 1,126
