Aller au contenu principal
Dell Inspiron 17-3721 Optical Drive Replacement
Ce dont vous avez besoin
  1. Dell Inspiron 17-3721 Optical Drive Replacement, Keyboard: étape 1, image 1 de 2 Dell Inspiron 17-3721 Optical Drive Replacement, Keyboard: étape 1, image 2 de 2
    • Use a plastic opening tool or a metal spudger to pry out the tabs on top of the keyboard.
    • After prying the tabs up, carefully pull the keyboard out of the laptop.
    • Use caution when prying the tabs up or lifting the keyboard up, as the plastic material and the strip on the keyboard can easily break.
  2. Dell Inspiron 17-3721 Optical Drive Replacement: étape 2, image 1 de 2 Dell Inspiron 17-3721 Optical Drive Replacement: étape 2, image 2 de 2
    • Once the keyboard is lifted, locate the release tab.
    • Using a plastic opening tool or your finger, lift the tab so that it opens .
    • Once the tab is open, the strip on the keyboard can be removed.
  3. Dell Inspiron 17-3721 Optical Drive Replacement, Optical Drive: étape 3, image 1 de 3 Dell Inspiron 17-3721 Optical Drive Replacement, Optical Drive: étape 3, image 2 de 3 Dell Inspiron 17-3721 Optical Drive Replacement, Optical Drive: étape 3, image 3 de 3
    • Remove the four 6 mm PH1 Philips head screws under the keyboard.
    • Carefully pop off the cover using the plastic opening tools and your hands.
  4. Dell Inspiron 17-3721 Optical Drive Replacement: étape 4, image 1 de 3 Dell Inspiron 17-3721 Optical Drive Replacement: étape 4, image 2 de 3 Dell Inspiron 17-3721 Optical Drive Replacement: étape 4, image 3 de 3
    • Remove the 4 mm PH1 Philips head screw holding down the optical drive.
    • Use your hand to slide the drive out of the device.
Kevin Prairie
Membre depuis le 03/20/18
445 Réputation
4 tutoriels rédigés
Équipe
UMass Dartmouth, Team S5-G3, Peak Spring 2018 Membre de l'équipe UMass Dartmouth, Team S5-G3, Peak Spring 2018
UMASSD-PEAK-S18S5G3
3 membres
7 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 15
30 derniers jours : 17
Total : 355
