Aller au contenu principal
Dell Inspiron 17-5749 Wireless Card Replacement
Ce dont vous avez besoin
  1. Dell Inspiron 17-5749 Wireless Card Replacement, Battery: étape 1, image 1 de 2 Dell Inspiron 17-5749 Wireless Card Replacement, Battery: étape 1, image 2 de 2
    Outil utilisé dans cette étape :
    Anti-Static Wrist Strap
    $7.95
    • Turn off power to the laptop.
    • Unplug the charging cable from the laptop.
    • Failure to unplug the charging cable could result in damaging the computer or seriously injuring yourself.
    • Wear the anti-static wrist strap or work in an uncarpeted area to prevent static shocks. Shocks may damage the components.
  2. Dell Inspiron 17-5749 Wireless Card Replacement: étape 2, image 1 de 2 Dell Inspiron 17-5749 Wireless Card Replacement: étape 2, image 2 de 2
    • First carefully turn the laptop over so you can access the battery.
    • Switch each of the battery latches to the "unlocked" position.
    • Pull battery upwards by the tab to remove from the laptop.
  3. Dell Inspiron 17-5749 Wireless Card Replacement, Back Cover: étape 3, image 1 de 3 Dell Inspiron 17-5749 Wireless Card Replacement, Back Cover: étape 3, image 2 de 3 Dell Inspiron 17-5749 Wireless Card Replacement, Back Cover: étape 3, image 3 de 3
    • Remove the two 5.5mm screws that secure the base cover to the computer's base.
    • Using the plastic opening tool, carefully pry open the base cover starting from the center.
    • Lift the base cover upwards to remove and set it aside.
  4. Dell Inspiron 17-5749 Wireless Card Replacement, Wireless Card: étape 4, image 1 de 3 Dell Inspiron 17-5749 Wireless Card Replacement, Wireless Card: étape 4, image 2 de 3 Dell Inspiron 17-5749 Wireless Card Replacement, Wireless Card: étape 4, image 3 de 3
    • Disconnect the antenna cables from the wireless card.
    • Push the securing tab to release the wireless card.
    • Slide the wireless card out of the wireless-card slot.
Christopher Tran
Membre depuis le 02/13/18
1 162 Réputation
12 tutoriels rédigés
Équipe
Washington State, Team S1-G2, Lobnitz Spring 2018 Membre de l'équipe Washington State, Team S1-G2, Lobnitz Spring 2018
WSU-LOBNITZ-S18S1G2
6 membres
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 5
7 derniers jours : 15
30 derniers jours : 15
Total : 276
