Aller au contenu principal
Dell Inspiron 17-5755 Keyboard Replacement
Ce dont vous avez besoin
  1. Dell Inspiron 17-5755 Keyboard Replacement, Battery: étape 1, image 1 de 1
    • Make sure the computer has been shut down, and isn't plugged into an outlet before attempting to remove the battery.
  2. Dell Inspiron 17-5755 Keyboard Replacement: étape 2, image 1 de 2 Dell Inspiron 17-5755 Keyboard Replacement: étape 2, image 2 de 2
    • Find the battery release latch on the bottom side of the computer.
    • Slide the latch to the left until you hear a "click". This indicates that the battery has been released.
  3. Dell Inspiron 17-5755 Keyboard Replacement: étape 3, image 1 de 1
    • Safely remove the battery from the laptop.
  4. Dell Inspiron 17-5755 Keyboard Replacement, Keyboard: étape 4, image 1 de 2 Dell Inspiron 17-5755 Keyboard Replacement, Keyboard: étape 4, image 2 de 2
    • Open the display of the laptop as far as possible, and locate the tabs which secure the keyboard to the laptop.
  5. Dell Inspiron 17-5755 Keyboard Replacement: étape 5, image 1 de 1
    • Use a plastic opening tool to gently release the tabs that secure the keyboard to the laptop.
  6. Dell Inspiron 17-5755 Keyboard Replacement: étape 6, image 1 de 2 Dell Inspiron 17-5755 Keyboard Replacement: étape 6, image 2 de 2
    • Carefully lift the keyboard from the laptop, being mindful of any attachments that it may have.
  7. Dell Inspiron 17-5755 Keyboard Replacement: étape 7, image 1 de 3 Dell Inspiron 17-5755 Keyboard Replacement: étape 7, image 2 de 3 Dell Inspiron 17-5755 Keyboard Replacement: étape 7, image 3 de 3
    • Lift the zero insertion force (ZIF) tab that secures the keyboard back light ribbon cable
    • Afterwards, carefully detach the backlight cable from the laptop.
  8. Dell Inspiron 17-5755 Keyboard Replacement: étape 8, image 1 de 3 Dell Inspiron 17-5755 Keyboard Replacement: étape 8, image 2 de 3 Dell Inspiron 17-5755 Keyboard Replacement: étape 8, image 3 de 3
    • Gently release the ZIF tab that secures the keyboard ribbon cable to the laptop.
    • Afterwards, carefully slide the cable out of its slot.
  9. Dell Inspiron 17-5755 Keyboard Replacement: étape 9, image 1 de 2 Dell Inspiron 17-5755 Keyboard Replacement: étape 9, image 2 de 2
    • Now that the keyboard is detached from the laptop, you may safely remove it.
3 autres ont terminé cette réparation.
Gabriel Espinal
Membre depuis le 02/15/17
248 Réputation
1 tutoriel rédigé
Équipe
USF Tampa, Team S6-G1, Lacy Spring 2017 Membre de l'équipe USF Tampa, Team S6-G1, Lacy Spring 2017
USFT-LACY-S17S6G1
3 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 10
30 derniers jours : 13
Total : 771
