Aller au contenu principal
Dell Inspiron 17-7737 Battery Replacement
Ce dont vous avez besoin
  1. Dell Inspiron 17-7737 Battery Replacement, Battery: étape 1, image 1 de 1
    • Close the display and turn the computer over.
    • Remove the 5 mm screw on the left-hand side of the battery cover using a Phillips #1 screwdriver.
    • Loosen the captive screw on the right-hand side using a Phillips #1 screwdriver.
  2. Dell Inspiron 17-7737 Battery Replacement: étape 2, image 1 de 3 Dell Inspiron 17-7737 Battery Replacement: étape 2, image 2 de 3 Dell Inspiron 17-7737 Battery Replacement: étape 2, image 3 de 3
    • Pry out the battery cover from the computer base using an opening tool.
  3. Dell Inspiron 17-7737 Battery Replacement: étape 3, image 1 de 1
    • Remove the three screws that secure the battery to the base using a Phillips #1 screwdriver.
  4. Dell Inspiron 17-7737 Battery Replacement: étape 4, image 1 de 2 Dell Inspiron 17-7737 Battery Replacement: étape 4, image 2 de 2
    • Using the adhesive pull tab, pull and lift the battery out of the computer's base.
    • If using any tools to get ahold of the adhesive tab, try not to puncture your battery, as battery acids are extremely toxic to humans.
Mark Batista
Membre depuis le 03/16/23
457 Réputation
3 tutoriels rédigés
Équipe
UMass Dartmouth, Team 7-7, Ryckebusch Spring 2023 Membre de l'équipe UMass Dartmouth, Team 7-7, Ryckebusch Spring 2023
UMASSD-RYCKEBUSCH-S23S7G7
3 membres
3 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 7
30 derniers jours : 18
Total : 401
