Aller au contenu principal
Dell Inspiron 17-7746 RAM Replacement
Ce dont vous avez besoin
  1. Dell Inspiron 17-7746 RAM Replacement, RAM: étape 1, image 1 de 1
    • Disconnect the Laptop from the AC adapter and turn off the Laptop.
  2. Dell Inspiron 17-7746 RAM Replacement: étape 2, image 1 de 1
    • Place the laptop so the bottom faces up.
  3. Dell Inspiron 17-7746 RAM Replacement: étape 3, image 1 de 3 Dell Inspiron 17-7746 RAM Replacement: étape 3, image 2 de 3 Dell Inspiron 17-7746 RAM Replacement: étape 3, image 3 de 3
    • Remove the silver 15mm PH 1 screw that holds the plastic cover in place over the battery.
    • Remove the silver 8mm screw that holds the plastic cover in place over the battery.
    • Keep these two screws together. Their size will matter when you reassemble.
  4. Dell Inspiron 17-7746 RAM Replacement: étape 4, image 1 de 1
    • Using the metal jimmy, pry up to remove the first half of the cover.
  5. Dell Inspiron 17-7746 RAM Replacement: étape 5, image 1 de 1
    • Apply pressure using your fingertips on the top of the cover and push toward the front of the laptop. This will make the plate slide off exposing the hard drive and battery.
  6. Dell Inspiron 17-7746 RAM Replacement: étape 6, image 1 de 1
    • Using the metal jimmy, remove the cover plate, this will expose the RAM.
  7. Dell Inspiron 17-7746 RAM Replacement: étape 7, image 1 de 2 Dell Inspiron 17-7746 RAM Replacement: étape 7, image 2 de 2
    • Apply outward pressure using fingers or a spudger on the small tabs on the RAM. Once freed the RAM will need to be lifted slightly, angling it upward, and then pulled out toward yourself.
Joshua Plagerman
Membre depuis le 09/26/18
735 Réputation
4 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 17
Total : 287
