Aller au contenu principal
Introduction
This model of computer has an integrated video card embedded in the Motherboard. If the computer seems to have the issues with a failing video card and it is not the drivers then the whole motherboard must be replaced.
  1. Disconnect the laptop from the AC adapter and turn off the laptop.
    • Disconnect the laptop from the AC adapter and turn off the laptop.
  2. Place the laptop so the bottom faces up.
    • Place the laptop so the bottom faces up.
  3. Remove the silver 15mm PH 1 screw that holds the plastic cover in place over the battery. Remove the  8mm PH 1 screw that holds the plastic cover in place over the battery. Keep the screws together because the length of the screws will matter when you reassemble.
    • Remove the silver 15mm PH 1 screw that holds the plastic cover in place over the battery.
    • Remove the 8mm PH 1 screw that holds the plastic cover in place over the battery.
    • Keep the screws together because the length of the screws will matter when you reassemble.
  4. Using the metal jimmy, pry up the first half of the cover.
    • Using the metal jimmy, pry up the first half of the cover.
  5. Apply pressure with your fingertips on top of the cover and drag toward the front of the laptop. This will make the plate slide off exposing the hard drive.
    • Apply pressure with your fingertips on top of the cover and drag toward the front of the laptop. This will make the plate slide off exposing the hard drive.
  6. Remove the two black PH1 6mm screws that anchor the battery. Remove the two black PH1 6mm screws that anchor the battery.
    • Remove the two black PH1 6mm screws that anchor the battery.
  7. Grab the black tab on the battery with index finger and thumb.
    • Grab the black tab on the battery with index finger and thumb.
    • If the Tab is broken or missing, use the plastic spudger to pry the battery out far enough to grab the battery by hand.
    • Avoid applying too much pressure on the battery with the plastic spudger. It might puncture the battery.
  8. Pull upwards, removing the battery from the laptop.
    • Pull upwards, removing the battery from the laptop.
    • Ensure replacement battery has no bulging or has no cracks and lies flat in its location.
  9. Remove the three black 6mm PH1 screws that anchor the hard drive. This screw hole will be empty because the 15mm silver screw that holds the plastic cover will anchor the hard drive down when completely reassembled. This screw hole will be empty because the 15mm silver screw that holds the plastic cover will anchor the hard drive down when completely reassembled.
    • Remove the three black 6mm PH1 screws that anchor the hard drive.
    • This screw hole will be empty because the 15mm silver screw that holds the plastic cover will anchor the hard drive down when completely reassembled.
  10. Using your hands, gently lift the hard drive out of its slot. Disconnect the Seta Cable attaching the hard drive to the laptop by gently wiggling loose the connector from the hard drive using your hands.
    • Using your hands, gently lift the hard drive out of its slot.
    • Disconnect the Seta Cable attaching the hard drive to the laptop by gently wiggling loose the connector from the hard drive using your hands.
  11. Pry up the plate covering the RAM, using  the metal jimmy.
    • Pry up the plate covering the RAM, using the metal jimmy.
  12. Remove all eleven (11) PH1 screws. Remove all eleven (11) PH1 screws.
    • Remove all eleven (11) PH1 screws.
  13. As part of removing all screws the CD ROM screw is also removed using the plastic spudger. Using the tip of the plastic spudger, push the metal tab towards the outer edge of the laptop. This pushes the CD ROM out. Using your fingers, pull out the CD ROM.
    • As part of removing all screws the CD ROM screw is also removed using the plastic spudger.
    • Using the tip of the plastic spudger, push the metal tab towards the outer edge of the laptop. This pushes the CD ROM out.
    • Using your fingers, pull out the CD ROM.
  14. Turn the laptop over and open it up, exposing the keyboard. Turn the laptop over and open it up, exposing the keyboard.
    • Turn the laptop over and open it up, exposing the keyboard.
  15. Using the plastic spudger tool, place the tip of the spudger into the small notches at the top of the keyboard and  push in the notch to release the top portion of the keyboard. Repeat on all notches. Push all five tabs back to lift the keyboard. Starting from the left to right makes it easier to remove the keyboard.
    • Using the plastic spudger tool, place the tip of the spudger into the small notches at the top of the keyboard and push in the notch to release the top portion of the keyboard. Repeat on all notches.
    • Push all five tabs back to lift the keyboard.
    • Starting from the left to right makes it easier to remove the keyboard.
  16. Using the plastic spudger, lift the top part of the keyboard and gently lift the keyboard out. Top of the keyboard is where the clips were holding the keyboard in place of the laptop.
    • Using the plastic spudger, lift the top part of the keyboard and gently lift the keyboard out.
    • Top of the keyboard is where the clips were holding the keyboard in place of the laptop.
    • There are flat ribbon cables that connect the keyboard, avoid breaking these cables.
    • Using your hands, gently remove the narrow flat ribbon cable from the motherboard port by gently pulling the cable.
  17. Using your hands, gently remove the wide flat ribbon cable from the motherboard port by gently pulling the cable.
    • Using your hands, gently remove the wide flat ribbon cable from the motherboard port by gently pulling the cable.
  18. Remove the 15mm PH 1 screw holding the bottom plate in place.
    • Remove the 15mm PH 1 screw holding the bottom plate in place.
  19. Close the laptop and flip it over exposing the bottom surface. Use the metal jimmy and blue opening tool, gently pry the bottom cover off. Repeat this process around the entire perimeter of the laptop. Close the laptop and flip it over exposing the bottom surface. Use the metal jimmy and blue opening tool, gently pry the bottom cover off. Repeat this process around the entire perimeter of the laptop.
    • Close the laptop and flip it over exposing the bottom surface. Use the metal jimmy and blue opening tool, gently pry the bottom cover off. Repeat this process around the entire perimeter of the laptop.
  20. Gently pick up the bottom cover, exposing all other components of the device.
    • Gently pick up the bottom cover, exposing all other components of the device.
    • If the cover is not coming off easily or seems to not be lifting off. Look for any screws you may have missed.
  21. The wireless card is near the left hinge of the laptop and has two little connectors attached to it. Gently lift the left black connector off the board and then lift the board out of the laptop. Repeat the same process with the white connector.
    • The wireless card is near the left hinge of the laptop and has two little connectors attached to it. Gently lift the left black connector off the board and then lift the board out of the laptop.
    • Repeat the same process with the white connector.
  22. Replace the wireless card and reconnect the black and white cables.
    • Replace the wireless card and reconnect the black and white cables.
    • Black cable goes to the connector on the wireless card labeled as "1."
    • White cable goes to the connector on the wireless card labeled as "2."
  23. Remove all wires and ribbon cables attached to the motherboard. Some Wires have small black tabs on top of them. Meaning one must grab the tab and pull directly upward, gently. Some ribbon cables may require the blue opening tool to release the cable's connectors before pulling it out.
    • Remove all wires and ribbon cables attached to the motherboard.
    • Some Wires have small black tabs on top of them. Meaning one must grab the tab and pull directly upward, gently.
    • Some ribbon cables may require the blue opening tool to release the cable's connectors before pulling it out.
    • Finally, some cables have a plastic head with small notches on the side. Use your hand to gently wiggle this cable side to side to remove.
    • The blue opening tool is recommended to avoid damaging the cables.
    • There should be a total of 8 wires/cables that must be removed from the motherboard.
  24. Remove the 6mm PH1 screw from the motherboard.
    • Remove the 6mm PH1 screw from the motherboard.
  25. Grab the board near where the RAM was, and gently pull and lift.
    • Grab the board near where the RAM was, and gently pull and lift.
    • If the board does not move, do not force it. This may mean you forgot to remove a screw or one of the cables.
    • Go ahead and replace the motherboard at this time.
Joshua Plagerman
Membre depuis le 26/09/2018
699 Réputation
4 tutoriels rédigés
Ajouter un commentaire
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 11
Total : 160
