Aller au contenu principal
Dell Inspiron 17" 7786 2-in-1 Base Cover Replacement
Ce dont vous avez besoin
  1. Dell Inspiron 17" 7786 2-in-1 Base Cover Replacement, Base Cover: étape 1, image 1 de 2 Dell Inspiron 17" 7786 2-in-1 Base Cover Replacement, Base Cover: étape 1, image 2 de 2
    • Remove the eight M2 5mm screws that secure the base cover using a Phillips #0 screwdriver.
  2. Dell Inspiron 17" 7786 2-in-1 Base Cover Replacement: étape 2, image 1 de 2 Dell Inspiron 17" 7786 2-in-1 Base Cover Replacement: étape 2, image 2 de 2
    • Loosen the three captive screws that secure the base closer to the hinges.
    • Do not attempt to remove the three captive screws! You need only to loosen them. They're supposed to stay on the base cover.
  3. Dell Inspiron 17" 7786 2-in-1 Base Cover Replacement: étape 3, image 1 de 3 Dell Inspiron 17" 7786 2-in-1 Base Cover Replacement: étape 3, image 2 de 3 Dell Inspiron 17" 7786 2-in-1 Base Cover Replacement: étape 3, image 3 de 3
    • Carefully pry the base cover using an iFixit opening tool in the crevice near the hinges. Guide the pick along the edges and slightly lift upwards as you go along.
    • Do not start from the speaker end of the edges when opening, or you may cause further damage to your device!
  4. Dell Inspiron 17" 7786 2-in-1 Base Cover Replacement: étape 4, image 1 de 3 Dell Inspiron 17" 7786 2-in-1 Base Cover Replacement: étape 4, image 2 de 3 Dell Inspiron 17" 7786 2-in-1 Base Cover Replacement: étape 4, image 3 de 3
    • Carefully remove the base cover from the laptop.
Delia Padilla
Membre depuis le 08/23/22
588 Réputation
5 tutoriels rédigés
Équipe
Gateway, Team 1-3, Class Fall 2022 Membre de l'équipe Gateway, Team 1-3, Class Fall 2022
GCC-CLASS-F22S1G3
4 membres
15 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 12
30 derniers jours : 15
Total : 183
