Aller au contenu principal
Dell Inspiron 17" 7786 2-in-1 Speakers Replacement
Ce dont vous avez besoin
  1. Dell Inspiron 17" 7786 2-in-1 Speakers Replacement, Base Cover: étape 1, image 1 de 2 Dell Inspiron 17" 7786 2-in-1 Speakers Replacement, Base Cover: étape 1, image 2 de 2
    • Remove the eight M2 5mm screws that secure the base cover using a Phillips #0 screwdriver.
  2. Dell Inspiron 17" 7786 2-in-1 Speakers Replacement: étape 2, image 1 de 2 Dell Inspiron 17" 7786 2-in-1 Speakers Replacement: étape 2, image 2 de 2
    • Loosen the three captive screws that secure the base closer to the hinges.
    • Do not attempt to remove the three captive screws! You need only to loosen them. They're supposed to stay on the base cover.
  3. Dell Inspiron 17" 7786 2-in-1 Speakers Replacement: étape 3, image 1 de 3 Dell Inspiron 17" 7786 2-in-1 Speakers Replacement: étape 3, image 2 de 3 Dell Inspiron 17" 7786 2-in-1 Speakers Replacement: étape 3, image 3 de 3
    • Carefully pry the base cover using an iFixit opening tool in the crevice near the hinges. Guide the pick along the edges and slightly lift upwards as you go along.
    • Do not start from the speaker end of the edges when opening, or you may cause further damage to your device!
  4. Dell Inspiron 17" 7786 2-in-1 Speakers Replacement: étape 4, image 1 de 3 Dell Inspiron 17" 7786 2-in-1 Speakers Replacement: étape 4, image 2 de 3 Dell Inspiron 17" 7786 2-in-1 Speakers Replacement: étape 4, image 3 de 3
    • Carefully remove the base cover from the laptop.
  5. Dell Inspiron 17" 7786 2-in-1 Speakers Replacement, Speakers: étape 5, image 1 de 2 Dell Inspiron 17" 7786 2-in-1 Speakers Replacement, Speakers: étape 5, image 2 de 2
    • Detach the cable that connects the speakers to the system board.
    • Starting with the speaker on the right hand area of the touch pad, carefully guide the speaker cabling out of the enclosure. You need only to lift upwards.
Antonio Franco
Membre depuis le 08/25/22
1 025 Réputation
10 tutoriels rédigés
Équipe
Gateway, Team 1-3, Class Fall 2022 Membre de l'équipe Gateway, Team 1-3, Class Fall 2022
GCC-CLASS-F22S1G3
4 membres
15 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 13
Total : 89
