Aller au contenu principal
Dell Inspiron 1721 Back Cover Replacement
Ce dont vous avez besoin
  1. Dell Inspiron 1721 Back Cover Replacement, Battery: étape 1, image 1 de 2 Dell Inspiron 1721 Back Cover Replacement, Battery: étape 1, image 2 de 2
    • Slide tabs outward to undo the locks.
    • Grab and pull the battery away from the device to remove.
  2. Dell Inspiron 1721 Back Cover Replacement, Hinge Plate Cover: étape 2, image 1 de 3 Dell Inspiron 1721 Back Cover Replacement, Hinge Plate Cover: étape 2, image 2 de 3 Dell Inspiron 1721 Back Cover Replacement, Hinge Plate Cover: étape 2, image 3 de 3
    • Pry up on the corner of the hinge cover with an iFixit opening tool.
    • Use the iFixit opening tool along both sides and the front of the hinge cover to release it.
    • Lean the display back as far as it goes and lift up on the hinge cover to remove.
  3. Dell Inspiron 1721 Back Cover Replacement, Display Assembly: étape 3, image 1 de 2 Dell Inspiron 1721 Back Cover Replacement, Display Assembly: étape 3, image 2 de 2
    • Loosen the two captive Phillips #0 screws.
    • Remove the cover.
  4. Dell Inspiron 1721 Back Cover Replacement: étape 4, image 1 de 1
    • Disconnect the antenna connectors from the WLAN card.
  5. Dell Inspiron 1721 Back Cover Replacement: étape 5, image 1 de 3 Dell Inspiron 1721 Back Cover Replacement: étape 5, image 2 de 3 Dell Inspiron 1721 Back Cover Replacement: étape 5, image 3 de 3
    • Remove the 3mm Phillips #0 screw securing the connector to the case ground.
    • Disconnect the display connector.
    • Disconnect the second connector, then remove the cable from the base.
  6. Dell Inspiron 1721 Back Cover Replacement: étape 6, image 1 de 3 Dell Inspiron 1721 Back Cover Replacement: étape 6, image 2 de 3 Dell Inspiron 1721 Back Cover Replacement: étape 6, image 3 de 3
    • Remove the display cable from the palm rest.
    • Use a spudger to carefully pull the antenna wires through to front of the device.
  7. Dell Inspiron 1721 Back Cover Replacement: étape 7, image 1 de 2 Dell Inspiron 1721 Back Cover Replacement: étape 7, image 2 de 2
    • Remove the two 3.5 mm Phillips screws that hold the display assembly in place.
    • Lift the assembly straight up to separate it from the body of the device.
  8. Dell Inspiron 1721 Back Cover Replacement, Back Cover: étape 8, image 1 de 1
    • Disconnect the touch pad connector.
  9. Dell Inspiron 1721 Back Cover Replacement: étape 9, image 1 de 3 Dell Inspiron 1721 Back Cover Replacement: étape 9, image 2 de 3 Dell Inspiron 1721 Back Cover Replacement: étape 9, image 3 de 3
    • Lay the device flat and remove the 17 7mm Phillips #0 screws.
    • Use an iFixit opening tool to separate the back cover.
    • Remove the back cover.
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 9
7 derniers jours : 18
30 derniers jours : 18
Total : 270
