Aller au contenu principal
Dell Inspiron 1721 LCD Screen Replacement
Ce dont vous avez besoin
  1. Dell Inspiron 1721 LCD Screen Replacement, Battery: étape 1, image 1 de 2 Dell Inspiron 1721 LCD Screen Replacement, Battery: étape 1, image 2 de 2
    • Slide tabs outward to undo the locks.
    • Grab and pull the battery away from the device to remove.
  2. Dell Inspiron 1721 LCD Screen Replacement, Hinge Plate Cover: étape 2, image 1 de 3 Dell Inspiron 1721 LCD Screen Replacement, Hinge Plate Cover: étape 2, image 2 de 3 Dell Inspiron 1721 LCD Screen Replacement, Hinge Plate Cover: étape 2, image 3 de 3
    • Pry up on the corner of the hinge cover with an iFixit opening tool.
    • Use the iFixit opening tool along both sides and the front of the hinge cover to release it.
    • Lean the display back as far as it goes and lift up on the hinge cover to remove.
  3. Dell Inspiron 1721 LCD Screen Replacement, Keyboard: étape 3, image 1 de 3 Dell Inspiron 1721 LCD Screen Replacement, Keyboard: étape 3, image 2 de 3 Dell Inspiron 1721 LCD Screen Replacement, Keyboard: étape 3, image 3 de 3
    • Remove four 3mm Phillips #1 screws from the top of the keyboard.
    • Use an iFixit opening tool to slide the keyboard upwards toward the display.
    • Slide the keyboard until it is clear of the lock tab, and lift it up to remove.
  4. Dell Inspiron 1721 LCD Screen Replacement, Display Assembly: étape 4, image 1 de 2 Dell Inspiron 1721 LCD Screen Replacement, Display Assembly: étape 4, image 2 de 2
    • Loosen the two captive Phillips #0 screws.
    • Remove the cover.
  5. Dell Inspiron 1721 LCD Screen Replacement: étape 5, image 1 de 1
    • Disconnect the antenna connectors from the WLAN card.
  6. Dell Inspiron 1721 LCD Screen Replacement: étape 6, image 1 de 3 Dell Inspiron 1721 LCD Screen Replacement: étape 6, image 2 de 3 Dell Inspiron 1721 LCD Screen Replacement: étape 6, image 3 de 3
    • Remove the 3mm Phillips #0 screw securing the connector to the case ground.
    • Disconnect the display connector.
    • Disconnect the second connector, then remove the cable from the base.
  7. Dell Inspiron 1721 LCD Screen Replacement: étape 7, image 1 de 3 Dell Inspiron 1721 LCD Screen Replacement: étape 7, image 2 de 3 Dell Inspiron 1721 LCD Screen Replacement: étape 7, image 3 de 3
    • Remove the display cable from the palm rest.
    • Use a spudger to carefully pull the antenna wires through to front of the device.
  8. Dell Inspiron 1721 LCD Screen Replacement: étape 8, image 1 de 2 Dell Inspiron 1721 LCD Screen Replacement: étape 8, image 2 de 2
    • Remove the two 3.5 mm Phillips screws that hold the display assembly in place.
    • Lift the assembly straight up to separate it from the body of the device.
  9. Dell Inspiron 1721 LCD Screen Replacement, LCD Screen: étape 9, image 1 de 2 Dell Inspiron 1721 LCD Screen Replacement, LCD Screen: étape 9, image 2 de 2
    • Remove the six Phillips #0 screws from the display case.
  10. Dell Inspiron 1721 LCD Screen Replacement: étape 10, image 1 de 3 Dell Inspiron 1721 LCD Screen Replacement: étape 10, image 2 de 3 Dell Inspiron 1721 LCD Screen Replacement: étape 10, image 3 de 3
    • Use an opening tool to remove the locks surrounding the display case.
  11. Dell Inspiron 1721 LCD Screen Replacement: étape 11, image 1 de 3 Dell Inspiron 1721 LCD Screen Replacement: étape 11, image 2 de 3 Dell Inspiron 1721 LCD Screen Replacement: étape 11, image 3 de 3
    • Use a Phillips #0 screwdriver to remove the eight screws surrounding the LCD display inside the display case.
    • Lift the LCD display up out of the display case.
  12. Dell Inspiron 1721 LCD Screen Replacement: étape 12, image 1 de 1
    • Remove the display cable from the display case to completely disconnect the LCD display.
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 8
7 derniers jours : 16
30 derniers jours : 16
Total : 286
