Aller au contenu principal
Dell Inspiron 17R-5737 Palmrest Replacement
Ce dont vous avez besoin
  1. Dell Inspiron 17R-5737 Palmrest Replacement, Battery: étape 1, image 1 de 1
    • Make sure the laptop is off before attempting to remove the battery.
    • Flip over your laptop so that the battery faces you.
  2. Dell Inspiron 17R-5737 Palmrest Replacement: étape 2, image 1 de 2 Dell Inspiron 17R-5737 Palmrest Replacement: étape 2, image 2 de 2
    • Slide each latch away from the battery to unlock it.
  3. Dell Inspiron 17R-5737 Palmrest Replacement: étape 3, image 1 de 2 Dell Inspiron 17R-5737 Palmrest Replacement: étape 3, image 2 de 2
    • Lift the battery upwards to remove it.
    • Continue holding the latches when removing the battery.
  4. Dell Inspiron 17R-5737 Palmrest Replacement, Optical Drive: étape 4, image 1 de 2 Dell Inspiron 17R-5737 Palmrest Replacement, Optical Drive: étape 4, image 2 de 2
    • Remove one 4.8mm screw with a JIS #00 screwdriver.
    • Remove the optical drive.
  5. Dell Inspiron 17R-5737 Palmrest Replacement, Access Panel: étape 5, image 1 de 1
    • Remove two 4.8mm screws with a JIS #00 screwdriver.
    • Remove the access panel.
  6. Dell Inspiron 17R-5737 Palmrest Replacement, Hard Drive: étape 6, image 1 de 3 Dell Inspiron 17R-5737 Palmrest Replacement, Hard Drive: étape 6, image 2 de 3 Dell Inspiron 17R-5737 Palmrest Replacement, Hard Drive: étape 6, image 3 de 3
    • Remove three 4.8mm screws from the hard drive with a JIS #00 screwdriver.
    • Slide the hard drive to the left.
    • Slide the hard drive to the right and up.
  7. Dell Inspiron 17R-5737 Palmrest Replacement, RAM: étape 7, image 1 de 2 Dell Inspiron 17R-5737 Palmrest Replacement, RAM: étape 7, image 2 de 2
    • Slide the two clips away from the RAM.
    • Lift the RAM out.
  8. Dell Inspiron 17R-5737 Palmrest Replacement, Keyboard: étape 8, image 1 de 1
    • A metal spudger can scratch delicate internal parts. Be extra careful when removing the keyboard.
    • Use a metal spudger to loosen the main frame of the keyboard.
    • A metal spudger should be used instead of a plastic one because a plastic one will probably break.
    • Make sure to get the spudger under the entire keyboard and not just under the keys.
  9. Dell Inspiron 17R-5737 Palmrest Replacement: étape 9, image 1 de 3 Dell Inspiron 17R-5737 Palmrest Replacement: étape 9, image 2 de 3 Dell Inspiron 17R-5737 Palmrest Replacement: étape 9, image 3 de 3
    • Slowly lift the keyboard.
    • Lift the locking flap that holds the ribbon cable in place.
    • The white line on this ribbon cable marks the edge of the connection area. To reinstall, insert the cable into the connector up to this line, and then close the locking flap.
    • Remove the keyboard.
  10. Dell Inspiron 17R-5737 Palmrest Replacement, Palmrest: étape 10, image 1 de 3 Dell Inspiron 17R-5737 Palmrest Replacement, Palmrest: étape 10, image 2 de 3 Dell Inspiron 17R-5737 Palmrest Replacement, Palmrest: étape 10, image 3 de 3
    • Remove two 1.6mm screws from beneath the optical drive with a JIS #00 screwdriver.
    • Remove the nine remaining 4.8mm screws from the back of the computer with a JIS #00 screwdriver.
  11. Dell Inspiron 17R-5737 Palmrest Replacement: étape 11, image 1 de 3 Dell Inspiron 17R-5737 Palmrest Replacement: étape 11, image 2 de 3 Dell Inspiron 17R-5737 Palmrest Replacement: étape 11, image 3 de 3
    • Remove the two exposed ribbon cables.
    • Remove the palmrest.
Mack Chabot
Membre depuis le 10/18/17
645 Réputation
6 tutoriels rédigés
Équipe
UMass Dartmouth, Team S3-G7, Bailey Fall 2017 Membre de l'équipe UMass Dartmouth, Team S3-G7, Bailey Fall 2017
UMASSD-BAILEY-F17S3G7
3 membres
11 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 2
Total : 224
