Aller au contenu principal
Dell Inspiron 17R-N7010 Fan Replacement
Ce dont vous avez besoin
  1. Dell Inspiron 17R-N7010 Fan Replacement, Battery: étape 1, image 1 de 1
    • Flip over the laptop so the back is facing upwards.
    • Locate the battery compartment.
    • Make sure your laptop is turned off before disassembly.
  2. Dell Inspiron 17R-N7010 Fan Replacement: étape 2, image 1 de 1
    • Slide both locks away from the center of the battery.
    • After you hear a click, pull out the battery.
  3. Dell Inspiron 17R-N7010 Fan Replacement, Palm Rest: étape 3, image 1 de 3 Dell Inspiron 17R-N7010 Fan Replacement, Palm Rest: étape 3, image 2 de 3 Dell Inspiron 17R-N7010 Fan Replacement, Palm Rest: étape 3, image 3 de 3
    • Remove the four screws from the back panel.
    • Flip the laptop over and open it to view the keyboard.
    • Disconnect the keyboard from the laptop by lifting up the latch holding the ribbon cable in place.
  4. Dell Inspiron 17R-N7010 Fan Replacement: étape 4, image 1 de 3 Dell Inspiron 17R-N7010 Fan Replacement: étape 4, image 2 de 3 Dell Inspiron 17R-N7010 Fan Replacement: étape 4, image 3 de 3
    • Close the laptop and flip it over so the bottom is facing upwards.
    • Remove the two screws from the small panel.
    • Remove the small back panel.
    • Slide the CD drive out of the laptop.
    • Remove the three screws from the CD drive slot.
  5. Dell Inspiron 17R-N7010 Fan Replacement: étape 5, image 1 de 1
    • This step is tricky and can feel like you are breaking the laptop. Follow the next steps with caution to avoid damaging the laptop.
    • Remove the top cover by inserting a spudger under the surface.
    • Working clockwise, pry upwards with the spudger to detach the clips.
  6. Dell Inspiron 17R-N7010 Fan Replacement: étape 6, image 1 de 2 Dell Inspiron 17R-N7010 Fan Replacement: étape 6, image 2 de 2
    • Disconnect the ribbon cables.
    • Remove the cover to access the inner hardware of the laptop.
  7. Dell Inspiron 17R-N7010 Fan Replacement, Fan: étape 7, image 1 de 3 Dell Inspiron 17R-N7010 Fan Replacement, Fan: étape 7, image 2 de 3 Dell Inspiron 17R-N7010 Fan Replacement, Fan: étape 7, image 3 de 3
    • Locate the fan at the top left corner.
    • Remove the fan by disconnecting the coupled wires from the white port.
    • Disconnect the wire strip by lifting up the latch holding the wire in place.
    • Unscrew the remaining two screws.
    • Remove the fan.
Brandon Lopez
Membre depuis le 09/21/18
319 Réputation
3 tutoriels rédigés
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 18
Total : 1,201
