Aller au contenu principal
Dell Inspiron 17R-N7110 RAM Replacement
Ce dont vous avez besoin
  1. Dell Inspiron 17R-N7110 RAM Replacement, Battery: étape 1, image 1 de 3 Dell Inspiron 17R-N7110 RAM Replacement, Battery: étape 1, image 2 de 3 Dell Inspiron 17R-N7110 RAM Replacement, Battery: étape 1, image 3 de 3
    Outil utilisé dans cette étape :
    Anti-Static Wrist Strap
    $7.95
    J'achète
    • Do not touch any electronic components without wearing the anti-static wrist strap. Failure to do so poses a risk of static electric shock, and may cause damage to components.
    • Place the laptop on a flat surface with the Dell logo upside down.
    • Flip the laptop over. The battery will be in the top center.
  2. Dell Inspiron 17R-N7110 RAM Replacement: étape 2, image 1 de 2 Dell Inspiron 17R-N7110 RAM Replacement: étape 2, image 2 de 2
    • Slide both the left lock and right lock, towards the center of the battery.
    • Push upwards on the grip on the bottom of the battery to remove it.
  3. Dell Inspiron 17R-N7110 RAM Replacement, RAM: étape 3, image 1 de 2 Dell Inspiron 17R-N7110 RAM Replacement, RAM: étape 3, image 2 de 2
    • Using a Phillips #1 screwdriver, unscrew the .7mm screw at the top of the RAM compartment as pictured.
    • Use a metal Jimmy to pry open the RAM cover from the top of the compartment.
  4. Dell Inspiron 17R-N7110 RAM Replacement: étape 4, image 1 de 3 Dell Inspiron 17R-N7110 RAM Replacement: étape 4, image 2 de 3 Dell Inspiron 17R-N7110 RAM Replacement: étape 4, image 3 de 3
    $7.95
    J'achète
    • Do not touch the RAM sticks without releasing static electricity build up. Make sure you are wearing the anti-static wrist strap, and that the metal clip is attached to a grounded metal object.
    • There are two small plastic prongs to the sides of the first RAM stick. Push the prongs away from each other to release the RAM stick.
    • Gently remove the RAM stick.
    • If your laptop has a second RAM stick located underneath the first one, repeat this step to remove it.
2 autres ont terminé cette réparation.
Emily Cone
Membre depuis le 04/09/18
1 366 Réputation
7 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 24
Total : 1,104
