Introduction
This guide will walk you through removing and replacing your Dell Inspiron 17R-N7110 RAM stick(s). You will be handling delicate electronic components during this process, so be sure to wear the anti-static wrist strap for this replacement.
Ce dont vous avez besoin
Outil utilisé dans cette étape :Anti-Static Wrist Strap$7.95
Place the laptop on a flat surface with the Dell logo upside down.
Flip the laptop over. The battery will be in the top center.
Using a Phillips #1 screwdriver, unscrew the .7mm screw at the top of the RAM compartment as pictured.
Use a metal Jimmy to pry open the RAM cover from the top of the compartment.
There are two small plastic prongs to the sides of the first RAM stick. Push the prongs away from each other to release the RAM stick.
Gently remove the RAM stick.
If your laptop has a second RAM stick located underneath the first one, repeat this step to remove it.
2 autres ont terminé cette réparation.
