Aller au contenu principal
Dell Inspiron 3148 CMOS Battery Replacement
Ce dont vous avez besoin
  1. Dell Inspiron 3148 CMOS Battery Replacement, Back Panel: étape 1, image 1 de 2 Dell Inspiron 3148 CMOS Battery Replacement, Back Panel: étape 1, image 2 de 2
    • Ensure the device is powered off and unplugged. Close the device and orient it face up, with the hinges further away from you.
    • Flip the device over so the backside is facing you.
  2. Dell Inspiron 3148 CMOS Battery Replacement: étape 2, image 1 de 1
    • Using the Phillips #1 screwdriver, remove all nine 7mm screws.
  3. Dell Inspiron 3148 CMOS Battery Replacement: étape 3, image 1 de 2 Dell Inspiron 3148 CMOS Battery Replacement: étape 3, image 2 de 2
    • Using the plastic opening tool, pull the back panel upward. Move the opening tool along the edge of the device and lift the panel off of your device.
    • Be aware, the back panel is kept in place by magnetic clips. They will offer some resistance, but continue to gently leverage upwards.
  4. Dell Inspiron 3148 CMOS Battery Replacement, CMOS Battery: étape 4, image 1 de 3 Dell Inspiron 3148 CMOS Battery Replacement, CMOS Battery: étape 4, image 2 de 3 Dell Inspiron 3148 CMOS Battery Replacement, CMOS Battery: étape 4, image 3 de 3
    Outil utilisé dans cette étape :
    J'achète
    • Using a pair of tweezers, lift the exposed edge of the CMOS battery upward.
    • Once the CMOS battery has been loosened, remove it from the device.
Christopher Gravelle
Membre depuis le 10/23/18
837 Réputation
7 tutoriels rédigés
Équipe
UMass Dartmouth, Team S1-G2, Simcock Fall 2018 Membre de l'équipe UMass Dartmouth, Team S1-G2, Simcock Fall 2018
UMASSD-SIMCOCK-F18S1G2
3 membres
7 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 20
Total : 272
