Aller au contenu principal
Dell Inspiron 3520 Optical Drive Replacement
Ce dont vous avez besoin
  1. Dell Inspiron 3520 Optical Drive Replacement, Battery: étape 1, image 1 de 2 Dell Inspiron 3520 Optical Drive Replacement, Battery: étape 1, image 2 de 2
    • Turn off notebook
    • Set the notebook upside down with the battery facing away from you.
    • Locate the unlock and release sliding tabs on the bottom right and left hand corners of the battery respectively.
  2. Dell Inspiron 3520 Optical Drive Replacement: étape 2, image 1 de 3 Dell Inspiron 3520 Optical Drive Replacement: étape 2, image 2 de 3 Dell Inspiron 3520 Optical Drive Replacement: étape 2, image 3 de 3
    • Slide the right tab to the right to unlock the battery.
    • Slide and hold the the left tab to the left to release the battery from the unit.
    • Finally, remove the battery by sliding it away from the unit and yourself.
  3. Dell Inspiron 3520 Optical Drive Replacement, Keyboard: étape 3, image 1 de 2 Dell Inspiron 3520 Optical Drive Replacement, Keyboard: étape 3, image 2 de 2
    • Locate the four tabs along the top edge of the keyboard.
    • Using the spudger, push the tabs away from the keyboard and pull the keyboard up away from the laptop.
  4. Dell Inspiron 3520 Optical Drive Replacement: étape 4, image 1 de 1
    • Slide the keyboard forward towards the screen to release the bottom tabs.
  5. Dell Inspiron 3520 Optical Drive Replacement: étape 5, image 1 de 2 Dell Inspiron 3520 Optical Drive Replacement: étape 5, image 2 de 2
    • Carefully lift the board up and locate the connecting cable.
    • Gently pull the end of the cable free from the port on the laptop.
  6. Dell Inspiron 3520 Optical Drive Replacement, Optical Drive: étape 6, image 1 de 2 Dell Inspiron 3520 Optical Drive Replacement, Optical Drive: étape 6, image 2 de 2
    • Locate and remove the 4mm Phillips #00 mounting screw.
  7. Dell Inspiron 3520 Optical Drive Replacement: étape 7, image 1 de 2 Dell Inspiron 3520 Optical Drive Replacement: étape 7, image 2 de 2
    • Push the optical drive from the inside a little bit to dislodge it.
    • Grab the drive with your hand from the outside and slide it free.
5 autres ont terminé cette réparation.
Ian
Membre depuis le 01/30/15
1 557 Réputation
5 tutoriels rédigés
Équipe
USF Tampa, Team 16-2, Watkins Winter 2015 Membre de l'équipe USF Tampa, Team 16-2, Watkins Winter 2015
USFT-WATKINS-W15S16G2
3 membres
5 tutoriels rédigés
Un commentaire
...screaming.....i love my dell 3520 it is awesome, it is still holding up.."hooray!!!!
Madeline Jones - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 13
30 derniers jours : 20
Total : 2,683
