Aller au contenu principal
Dell Inspiron 3520 RAM Replacement
Ce dont vous avez besoin
  1. Dell Inspiron 3520 RAM Replacement, Battery: étape 1, image 1 de 2 Dell Inspiron 3520 RAM Replacement, Battery: étape 1, image 2 de 2
    • Turn off notebook
    • Set the notebook upside down with the battery facing away from you.
    • Locate the unlock and release sliding tabs on the bottom right and left hand corners of the battery respectively.
  2. Dell Inspiron 3520 RAM Replacement: étape 2, image 1 de 3 Dell Inspiron 3520 RAM Replacement: étape 2, image 2 de 3 Dell Inspiron 3520 RAM Replacement: étape 2, image 3 de 3
    • Slide the right tab to the right to unlock the battery.
    • Slide and hold the the left tab to the left to release the battery from the unit.
    • Finally, remove the battery by sliding it away from the unit and yourself.
  3. Dell Inspiron 3520 RAM Replacement, Keyboard: étape 3, image 1 de 2 Dell Inspiron 3520 RAM Replacement, Keyboard: étape 3, image 2 de 2
    • Locate the four tabs along the top edge of the keyboard.
    • Using the spudger, push the tabs away from the keyboard and pull the keyboard up away from the laptop.
  4. Dell Inspiron 3520 RAM Replacement: étape 4, image 1 de 1
    • Slide the keyboard forward towards the screen to release the bottom tabs.
  5. Dell Inspiron 3520 RAM Replacement: étape 5, image 1 de 2 Dell Inspiron 3520 RAM Replacement: étape 5, image 2 de 2
    • Carefully lift the board up and locate the connecting cable.
    • Gently pull the end of the cable free from the port on the laptop.
  6. Dell Inspiron 3520 RAM Replacement, RAM: étape 6, image 1 de 1
    • Locate the RAM chip(s)
    • There are no RAM chips present in this photo.
  7. Dell Inspiron 3520 RAM Replacement: étape 7, image 1 de 2 Dell Inspiron 3520 RAM Replacement: étape 7, image 2 de 2
    • There are two connecting pins for the lower chip.
    • There are two connecting pins for the upper chip.
    • Pull the pins away from the sides of the chip(s) to release it.
    • The chip(s) should slide away from the dock easily.
17 autres ont terminé cette réparation.
Ian
Membre depuis le 01/30/15
1 506 Réputation
5 tutoriels rédigés
Équipe
USF Tampa, Team 16-2, Watkins Winter 2015 Membre de l'équipe USF Tampa, Team 16-2, Watkins Winter 2015
USFT-WATKINS-W15S16G2
3 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 29
30 derniers jours : 83
Total : 31,654
