Aller au contenu principal
Dell Inspiron 5100 (2015) Thermal Paste Replacement
Ce dont vous avez besoin
  1. Dell Inspiron 5100 (2015) Thermal Paste Replacement, Thermal Paste: étape 1, image 1 de 3 Dell Inspiron 5100 (2015) Thermal Paste Replacement, Thermal Paste: étape 1, image 2 de 3 Dell Inspiron 5100 (2015) Thermal Paste Replacement, Thermal Paste: étape 1, image 3 de 3
    • Use the slider to release and remove the battery.
    • Remove the 11 screws using a small tip Phillips screwdriver.
  2. Dell Inspiron 5100 (2015) Thermal Paste Replacement: étape 2, image 1 de 3 Dell Inspiron 5100 (2015) Thermal Paste Replacement: étape 2, image 2 de 3 Dell Inspiron 5100 (2015) Thermal Paste Replacement: étape 2, image 3 de 3
    • Use a flat screw driver to pry against the angled metal.
    • Remove the 3 small screws that were under the optical drive using a small tip Phillips screwdriver.
  3. Dell Inspiron 5100 (2015) Thermal Paste Replacement: étape 3, image 1 de 3 Dell Inspiron 5100 (2015) Thermal Paste Replacement: étape 3, image 2 de 3 Dell Inspiron 5100 (2015) Thermal Paste Replacement: étape 3, image 3 de 3
    • Use a small flat-head screwdriver to pry up at each point indicated to unclip the keyboard from the chassis.
    • Lift the keyboard 2-3 inches up and carefully disconnect the two ribbon cables by unlatching the mechanism and carefully sliding the cable out horizontally.
    • Place the keyboard to the side.
  4. Dell Inspiron 5100 (2015) Thermal Paste Replacement: étape 4, image 1 de 3 Dell Inspiron 5100 (2015) Thermal Paste Replacement: étape 4, image 2 de 3 Dell Inspiron 5100 (2015) Thermal Paste Replacement: étape 4, image 3 de 3
    • Remove the 5 screws using the small Phillips screwdriver.
  5. Dell Inspiron 5100 (2015) Thermal Paste Replacement: étape 5, image 1 de 3 Dell Inspiron 5100 (2015) Thermal Paste Replacement: étape 5, image 2 de 3 Dell Inspiron 5100 (2015) Thermal Paste Replacement: étape 5, image 3 de 3
    • Grab the bottom panel where the optical drive was and lift straight up.
    • It should start popping clips and then come off without much force required.
    • Pay special attention to not break any plastic clips.
  6. Dell Inspiron 5100 (2015) Thermal Paste Replacement: étape 6, image 1 de 3 Dell Inspiron 5100 (2015) Thermal Paste Replacement: étape 6, image 2 de 3 Dell Inspiron 5100 (2015) Thermal Paste Replacement: étape 6, image 3 de 3
    • Loosen the screws one at a time and repeat until they are fully unscrewed.
    • Unplug the fan cable from the header by sliding it out horizontally.
    • Lift the cooler off the CPU with one hand on the CPU area and one hand on the fan assembly.
  7. Dell Inspiron 5100 (2015) Thermal Paste Replacement: étape 7, image 1 de 3 Dell Inspiron 5100 (2015) Thermal Paste Replacement: étape 7, image 2 de 3 Dell Inspiron 5100 (2015) Thermal Paste Replacement: étape 7, image 3 de 3
    • Using paper towels, q-tips, and isopropyl alcohol, clean off the old thermal paste on the CPU and heatsink.
    • Be careful around the CPU; it is delicate and can be damaged.
  8. Dell Inspiron 5100 (2015) Thermal Paste Replacement: étape 8, image 1 de 2 Dell Inspiron 5100 (2015) Thermal Paste Replacement: étape 8, image 2 de 2
    • Apply a grain of rice amount of thermal paste to the CPU in the indicated spots.
Dominic Treadwell
Membre depuis le 07/09/23
184 Réputation
1 tutoriel rédigé
Équipe
Austin Community College, Team 1-8, Meigs Summer 2023 Membre de l'équipe Austin Community College, Team 1-8, Meigs Summer 2023
AUSTINCC-MEIGS-SU23S1G8
1 membre
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 26
Total : 205
