Aller au contenu principal
Introduction
You will be able to access wires connecting your screen and replace it if needed.
Pièces
Aucune pièce spécifiée.
  1. Remove battery
    • Remove battery
    • Open screen so that it lies flat.
  2. Starting from the right side of the hinge cover,  use the flat end of the spudger to pry up the hinge cover and gently remove it. Starting from the right side of the hinge cover,  use the flat end of the spudger to pry up the hinge cover and gently remove it.
    • Starting from the right side of the hinge cover, use the flat end of the spudger to pry up the hinge cover and gently remove it.
  3. Remove the four M2 x 3-mm screws holding in the keyboard. Remove the four M2 x 3-mm screws holding in the keyboard.
    • Remove the four M2 x 3-mm screws holding in the keyboard.
  4. Lift keyboard and detach the interface connector.
    • Lift keyboard and detach the interface connector.
    • Take extra care when removing and handling the keyboard. The key caps on the keyboard are fragile, easily dislocate and would be time-consuming to replace.
  5. Remove two screws (5.8mm) located at the rear of the laptop. Remove two screws (5.8mm) located at the rear of the laptop.
    • Remove two screws (5.8mm) located at the rear of the laptop.
  6. Detach screen connector.
    • Detach screen connector.
  7. Remove four screws (5.8 mm) located at hinges of the screen. Remove four screws (5.8 mm) located at hinges of the screen.
    • Remove four screws (5.8 mm) located at hinges of the screen.
  8. Lift and remove display screen.
    • Lift and remove display screen.
May Chauvin
Membre depuis le 14/04/2011
201 Réputation
6 tutoriels rédigés
Équipe
Cal Poly, Team 12-34, Maness Spring 2011 Membre de l'équipe Cal Poly, Team 12-34, Maness Spring 2011
CPSU-MANESS-S11S12G34
4 membres
6 tutoriels rédigés
Ajouter un commentaire
Voir les statistiques:
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 10
Total : 2,901
