Aller au contenu principal
Dell Inspiron 5758 DC Jack Replacement
Ce dont vous avez besoin
  1. Dell Inspiron 5758 DC Jack Replacement, Battery: étape 1, image 1 de 2 Dell Inspiron 5758 DC Jack Replacement, Battery: étape 1, image 2 de 2
    • Flip the laptop with the serial number facing up. You should be able to see the battery release switch.
  2. Dell Inspiron 5758 DC Jack Replacement: étape 2, image 1 de 3 Dell Inspiron 5758 DC Jack Replacement: étape 2, image 2 de 3 Dell Inspiron 5758 DC Jack Replacement: étape 2, image 3 de 3
    • Slide the battery release switch towards the unlock icon.
    • You should hear a click.
    • Lift and pull the ejected battery to remove it.
  3. Dell Inspiron 5758 DC Jack Replacement, DC Jack: étape 3, image 1 de 3 Dell Inspiron 5758 DC Jack Replacement, DC Jack: étape 3, image 2 de 3 Dell Inspiron 5758 DC Jack Replacement, DC Jack: étape 3, image 3 de 3
    • Remove the one 3mm optical drive screw.
    • Remove the two 8 mm screws.
    • Pry up and remove the access door.
  4. Dell Inspiron 5758 DC Jack Replacement: étape 4, image 1 de 1
    • Remove the one 3 mm screw.
    • Remove the bracket.
  5. Dell Inspiron 5758 DC Jack Replacement: étape 5, image 1 de 2 Dell Inspiron 5758 DC Jack Replacement: étape 5, image 2 de 2
    • Unplug the antenna cables.
    • Remove the Wireless Card.
  6. Dell Inspiron 5758 DC Jack Replacement: étape 6, image 1 de 2 Dell Inspiron 5758 DC Jack Replacement: étape 6, image 2 de 2
    • Unplug the hard drive cable.
    • Use a plastic opening tool or your fingernail to pop the tab of the cable connector. Then you will be able to disconnect the cable.
    • Remove the four 8 mm screws.
    • Remove the hard drive.
  7. Dell Inspiron 5758 DC Jack Replacement: étape 7, image 1 de 3 Dell Inspiron 5758 DC Jack Replacement: étape 7, image 2 de 3 Dell Inspiron 5758 DC Jack Replacement: étape 7, image 3 de 3
    • Remove the two 3 mm screws under the battery.
    • Remove the three 2 mm wafer screws under the optical drive.
    • Remove the ten 8 mm base screws.
  8. Dell Inspiron 5758 DC Jack Replacement: étape 8, image 1 de 1
    • Unplug the speaker cable by sliding to the right.
  9. Dell Inspiron 5758 DC Jack Replacement: étape 9, image 1 de 2 Dell Inspiron 5758 DC Jack Replacement: étape 9, image 2 de 2
    • Press in the tabs to loosen the keyboard.
    • Carefully lift the keyboard up and turn it over.
  10. Dell Inspiron 5758 DC Jack Replacement: étape 10, image 1 de 1
    • Unplug the keyboard cable & remove the keyboard.
  11. Dell Inspiron 5758 DC Jack Replacement: étape 11, image 1 de 2 Dell Inspiron 5758 DC Jack Replacement: étape 11, image 2 de 2
    • Slide the DVD optical drive over & remove it from the laptop.
  12. Dell Inspiron 5758 DC Jack Replacement: étape 12, image 1 de 2 Dell Inspiron 5758 DC Jack Replacement: étape 12, image 2 de 2
    • Remove the four 5 mm screws.
    • Unplug the optical drive interposer cable.
  13. Dell Inspiron 5758 DC Jack Replacement: étape 13, image 1 de 2 Dell Inspiron 5758 DC Jack Replacement: étape 13, image 2 de 2
    • Unplug the power button cable.
    • Unplug the touchpad cable.
  14. Dell Inspiron 5758 DC Jack Replacement: étape 14, image 1 de 3 Dell Inspiron 5758 DC Jack Replacement: étape 14, image 2 de 3 Dell Inspiron 5758 DC Jack Replacement: étape 14, image 3 de 3
    • Carefully pry off & loosen the bottom base.
  15. Dell Inspiron 5758 DC Jack Replacement: étape 15, image 1 de 1
    • Remove the bottom base.
  16. Dell Inspiron 5758 DC Jack Replacement: étape 16, image 1 de 2 Dell Inspiron 5758 DC Jack Replacement: étape 16, image 2 de 2
    • Remove the one 5mm screw.
    • Lift the circuit board & turn it over.
    • Unplug the cable.
    • Remove the audio/USB circuit board.
  17. Dell Inspiron 5758 DC Jack Replacement: étape 17, image 1 de 3 Dell Inspiron 5758 DC Jack Replacement: étape 17, image 2 de 3 Dell Inspiron 5758 DC Jack Replacement: étape 17, image 3 de 3
    • Loosen the audio / USB cable.
    • Remove the one 3mm motherboard screw.
    • Lift the motherboard & carefully move it out of the way.
  18. Dell Inspiron 5758 DC Jack Replacement: étape 18, image 1 de 3 Dell Inspiron 5758 DC Jack Replacement: étape 18, image 2 de 3 Dell Inspiron 5758 DC Jack Replacement: étape 18, image 3 de 3
    • Unplug the DC jack cable.
    • Remove the one 3mm screw.
    • Remove the DC Jack.
Antonio Zuniga
Membre depuis le 09/18/18
273 Réputation
1 tutoriel rédigé
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 6
30 derniers jours : 10
Total : 1,020
