Aller au contenu principal
Dell Inspiron 6000 Fan Replacement
Ce dont vous avez besoin
  1. Dell Inspiron 6000 Fan Replacement, Battery: étape 1, image 1 de 1
    • To prevent injury, make sure the laptop is unplugged before removing the battery.
    • Flip the laptop over, bottom-side up.
  2. Dell Inspiron 6000 Fan Replacement: étape 2, image 1 de 1
    • Push the switch next to the battery.
    • At the same time, lift the battery away from the laptop.
  3. Dell Inspiron 6000 Fan Replacement, Keyboard: étape 3, image 1 de 3 Dell Inspiron 6000 Fan Replacement, Keyboard: étape 3, image 2 de 3 Dell Inspiron 6000 Fan Replacement, Keyboard: étape 3, image 3 de 3
    • Place the laptop on flat surface.
    • Carefully open the laptop at far as it will go so that the back of screen is touching the flat surface.
    • Carefully take a spudger and separate part of the cover at the red circle.
  4. Dell Inspiron 6000 Fan Replacement: étape 4, image 1 de 2 Dell Inspiron 6000 Fan Replacement: étape 4, image 2 de 2
    • Remove two 4 mm Philips #00 screws.
  5. Dell Inspiron 6000 Fan Replacement: étape 5, image 1 de 1
    • Gently lift the keyboard away from the laptop without harming the cord that is located at the bottom of the keyboard.
  6. Dell Inspiron 6000 Fan Replacement: étape 6, image 1 de 3 Dell Inspiron 6000 Fan Replacement: étape 6, image 2 de 3 Dell Inspiron 6000 Fan Replacement: étape 6, image 3 de 3
    • Gently pull the blue tab up until it comes away from computer.
  7. Dell Inspiron 6000 Fan Replacement, Fan: étape 7, image 1 de 1
    • Unscrew the 4 mm Phillips #00 screw.
    • The screw will remain attached to the cord when fully removed.
  8. Dell Inspiron 6000 Fan Replacement: étape 8, image 1 de 2 Dell Inspiron 6000 Fan Replacement: étape 8, image 2 de 2
    • Gently pull the blue tab to separate the screen connection from the laptop.
    • Gently pull and disconnect the white and black cords from the power source.
  9. Dell Inspiron 6000 Fan Replacement: étape 9, image 1 de 2 Dell Inspiron 6000 Fan Replacement: étape 9, image 2 de 2
    • Remove four 4mm #00 Philips screws from the screen hinges.
    • Lift the screen away from the laptop.
  10. Dell Inspiron 6000 Fan Replacement: étape 10, image 1 de 2 Dell Inspiron 6000 Fan Replacement: étape 10, image 2 de 2
    • Remove two 4 mm Philips #00 screws that connect top of laptop to base..
  11. Dell Inspiron 6000 Fan Replacement: étape 11, image 1 de 1
    • Flip laptop the over and remove thirteen 6mm Philips #00 screws.
  12. Dell Inspiron 6000 Fan Replacement: étape 12, image 1 de 2 Dell Inspiron 6000 Fan Replacement: étape 12, image 2 de 2
    • Insert the plastic opening tool in between the back and front plates of the laptop
  13. Dell Inspiron 6000 Fan Replacement: étape 13, image 1 de 1
  14. Dell Inspiron 6000 Fan Replacement: étape 14, image 1 de 1
    • Remove the fan power cord
  15. Dell Inspiron 6000 Fan Replacement: étape 15, image 1 de 2 Dell Inspiron 6000 Fan Replacement: étape 15, image 2 de 2
    • Using your hand, lift the fan from the laptop.
5 autres ont terminé cette réparation.
Jacob DeWar
Membre depuis le 09/23/14
533 Réputation
3 tutoriels rédigés
Équipe
USF Tampa, Team 11-1, Blackwell Fall 2014 Membre de l'équipe USF Tampa, Team 11-1, Blackwell Fall 2014
USFT-BLACKWELL-F14S11G1
5 membres
7 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 9
30 derniers jours : 16
Total : 2,308
