Aller au contenu principal
Dell Inspiron 600m Keyboard Replacement
Ce dont vous avez besoin
  1. Dell Inspiron 600m Keyboard Replacement, Battery: étape 1, image 1 de 3 Dell Inspiron 600m Keyboard Replacement, Battery: étape 1, image 2 de 3 Dell Inspiron 600m Keyboard Replacement, Battery: étape 1, image 3 de 3
    • Flip laptop upside down and locate the battery as shown in the images.
    • Push in the tab on the battery and lift up. The battery should detach very easily.
  2. Dell Inspiron 600m Keyboard Replacement, Keyboard: étape 2, image 1 de 1
    • Orient laptop with the keyboard facing upward and the lid open.
  3. Dell Inspiron 600m Keyboard Replacement: étape 3, image 1 de 3 Dell Inspiron 600m Keyboard Replacement: étape 3, image 2 de 3 Dell Inspiron 600m Keyboard Replacement: étape 3, image 3 de 3
    • Caution the face plate is a fragile piece of plastic. Handle carefully.
    • Start in the upper right corner and work to the left when removing the face plate (includes power button and volume controls).
    • Use a flathead screwdriver (or anything flat and strong) to wedge underneath the face plate.
    • Carefully lift the screwdriver to remove the face plate.
  4. Dell Inspiron 600m Keyboard Replacement: étape 4, image 1 de 3 Dell Inspiron 600m Keyboard Replacement: étape 4, image 2 de 3 Dell Inspiron 600m Keyboard Replacement: étape 4, image 3 de 3
    • Use a the Phillips screwdriver to remove the two screws.
  5. Dell Inspiron 600m Keyboard Replacement: étape 5, image 1 de 1
    • Gently slide keyboard toward screen.
    • Lift keyboard carefully. It is attached by a ribbon cable.
  6. Dell Inspiron 600m Keyboard Replacement: étape 6, image 1 de 3 Dell Inspiron 600m Keyboard Replacement: étape 6, image 2 de 3 Dell Inspiron 600m Keyboard Replacement: étape 6, image 3 de 3
    • Pull upward on blue tab to disconnect keyboard.
3 autres ont terminé cette réparation.
Peter Hallsten
Membre depuis le 04/01/11
148 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 10-40, Forte Spring 2011 Membre de l'équipe Cal Poly, Team 10-40, Forte Spring 2011
CPSU-FORTE-S11S10G40
5 membres
8 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 12
Total : 3,468
