Aller au contenu principal
Dell Inspiron 7486 Chromebook Battery Replacement
Ce dont vous avez besoin
  1. Dell Inspiron 7486 Chromebook Battery Replacement, Battery: étape 1, image 1 de 2 Dell Inspiron 7486 Chromebook Battery Replacement, Battery: étape 1, image 2 de 2
    • Power off your Chromebook and unplug it from the AC adapter before starting.
    • Remove the seven 6 mm screws securing the base cover with a Phillips #1 screwdriver.
  2. Dell Inspiron 7486 Chromebook Battery Replacement: étape 2, image 1 de 2 Dell Inspiron 7486 Chromebook Battery Replacement: étape 2, image 2 de 2
    • Unscrew the three captive screws with a Phillips #1 screwdriver.
  3. Dell Inspiron 7486 Chromebook Battery Replacement: étape 3, image 1 de 2 Dell Inspiron 7486 Chromebook Battery Replacement: étape 3, image 2 de 2
    • Gently pry the base cover loose at the hinges with a plastic opening tool.
    • Carefully run your fingertips along the edges of the base cover to remove it.
  4. Dell Inspiron 7486 Chromebook Battery Replacement: étape 4, image 1 de 3 Dell Inspiron 7486 Chromebook Battery Replacement: étape 4, image 2 de 3 Dell Inspiron 7486 Chromebook Battery Replacement: étape 4, image 3 de 3
    • Using a Phillips #0 screwdriver, remove the two 4 mm screws securing the battery cable bracket to the motherboard.
    • Remove the battery cable bracket.
  5. Dell Inspiron 7486 Chromebook Battery Replacement: étape 5, image 1 de 2 Dell Inspiron 7486 Chromebook Battery Replacement: étape 5, image 2 de 2
    • Using a Phillips #0 screwdriver, remove the four 3 mm screws that secure the battery to the motherboard.
  6. Dell Inspiron 7486 Chromebook Battery Replacement: étape 6, image 1 de 3 Dell Inspiron 7486 Chromebook Battery Replacement: étape 6, image 2 de 3 Dell Inspiron 7486 Chromebook Battery Replacement: étape 6, image 3 de 3
    • Pull the tab on the battery cable to disconnect it from the motherboard.
    • Remove the battery.
4 autres ont terminé cette réparation.
[deleted]
Membre depuis le 09/19/20
265 Réputation
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 15
Total : 587
