Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Dell Inspiron 7568 Display Assembly Replacement Guide
Ce dont vous avez besoin
  1. Dell Inspiron 7568 Display Assembly Replacement Guide, Battery: étape 1, image 1 de 2 Dell Inspiron 7568 Display Assembly Replacement Guide, Battery: étape 1, image 2 de 2
    • Remove the ten 7mm Phillips #1 screws on the bottom cover.
    • Remove the bottom cover.
    Demander à FixBot
  2. Dell Inspiron 7568 Display Assembly Replacement Guide: étape 2, image 1 de 2 Dell Inspiron 7568 Display Assembly Replacement Guide: étape 2, image 2 de 2
    • Remove the four 3mm Phillips #1 screws holding the battery.
    • Unhinge the connector cable to the battery.
    • Remove the battery.
    Demander à FixBot
  3. Dell Inspiron 7568 Display Assembly Replacement Guide, Display Assembly: étape 3, image 1 de 2 Dell Inspiron 7568 Display Assembly Replacement Guide, Display Assembly: étape 3, image 2 de 2
    • Unscrew & remove the two 3mm screws (using a ph1 screwdriver bit) and the cable bracket, above the motherboard
    • Doing this will allow one to access the LCD-motherboard connector cables.
    Demander à FixBot
  4. Dell Inspiron 7568 Display Assembly Replacement Guide: étape 4, image 1 de 2 Dell Inspiron 7568 Display Assembly Replacement Guide: étape 4, image 2 de 2
    • Unscrew the 7mm screws that secure the left and right hinges (using a ph1 screwdriver bit).
    Demander à FixBot
  5. Dell Inspiron 7568 Display Assembly Replacement Guide: étape 5, image 1 de 3 Dell Inspiron 7568 Display Assembly Replacement Guide: étape 5, image 2 de 3 Dell Inspiron 7568 Display Assembly Replacement Guide: étape 5, image 3 de 3
    • Disconnect the antenna cable (under the left hinge)
    • Disconnect the LCD and Touchscreen display cables under the right hinge.
    • These are a set of two cables. For better image see image two in step one of this guide.
    Demander à FixBot
  6. Dell Inspiron 7568 Display Assembly Replacement Guide: étape 6, image 1 de 1
    • Carefully separate the screen from the bottom half of the device.
    Demander à FixBot
2 autres ont terminé cette réparation.
Yash Samant
Membre depuis le 02/22/17
406 Réputation
3 tutoriels rédigés
Équipe
USF Tampa, Team S2-G2, Lacy Spring 2017 Membre de l'équipe USF Tampa, Team S2-G2, Lacy Spring 2017
USFT-LACY-S17S2G2
4 membres
7 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 7
30 derniers jours : 27
Total : 1,230
