Aller au contenu principal
Dell Inspiron 7568 Hard-Drive Replacement
Ce dont vous avez besoin
  1. Dell Inspiron 7568 Hard-Drive Replacement, Battery: étape 1, image 1 de 2 Dell Inspiron 7568 Hard-Drive Replacement, Battery: étape 1, image 2 de 2
    • Remove the ten 7mm Phillips #1 screws on the bottom cover.
    • Remove the bottom cover.
  2. Dell Inspiron 7568 Hard-Drive Replacement: étape 2, image 1 de 2 Dell Inspiron 7568 Hard-Drive Replacement: étape 2, image 2 de 2
    • Remove the four 3mm Phillips #1 screws holding the battery.
    • Unhinge the connector cable to the battery.
    • Remove the battery.
  3. Dell Inspiron 7568 Hard-Drive Replacement, Hard-Drive: étape 3, image 1 de 1
    • Remove the three 3mm Phillips #1 screws connecting the hard drive to the laptop.
  4. Dell Inspiron 7568 Hard-Drive Replacement: étape 4, image 1 de 2 Dell Inspiron 7568 Hard-Drive Replacement: étape 4, image 2 de 2
    • Disconnect the highlighted SATA cable from the hard drive.
  5. Dell Inspiron 7568 Hard-Drive Replacement: étape 5, image 1 de 1
    • Remove the four 3mm Phillips #1 screws of the hard drive. Both sides look identical.
  6. Dell Inspiron 7568 Hard-Drive Replacement: étape 6, image 1 de 1
    • Remove the hard drive (right) from its frame (left).
Elijah Basile
Membre depuis le 11/06/19
358 Réputation
4 tutoriels rédigés
Équipe
IUPUI, Team S1-G4, Stella Fall 2019 Membre de l'équipe IUPUI, Team S1-G4, Stella Fall 2019
IUPUI-STELLA-F19S1G4
4 membres
4 tutoriels rédigés
Un commentaire
Will a 9mm 2.5” SSD fit in these? or can it be forced in? p16 of the spec sheet says “7mm” but I’m not sure if that’s just saying stock configuration just comes with a 7mm drive? or that it only supports up to 7mm?: https://dl.dell.com/manuals/all-products... Any clarification appreciated, thanks!
Blacknova - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 3
Total : 393
