Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Dell Inspiron 7568 Keyboard Replacement Guide
Ce dont vous avez besoin
  1. Dell Inspiron 7568 Keyboard Replacement Guide, Battery: étape 1, image 1 de 2 Dell Inspiron 7568 Keyboard Replacement Guide, Battery: étape 1, image 2 de 2
    • Remove the ten 7mm Phillips #1 screws on the bottom cover.
    • Remove the bottom cover.
    Demander à FixBot
  2. Dell Inspiron 7568 Keyboard Replacement Guide: étape 2, image 1 de 2 Dell Inspiron 7568 Keyboard Replacement Guide: étape 2, image 2 de 2
    • Remove the four 3mm Phillips #1 screws holding the battery.
    • Unhinge the connector cable to the battery.
    • Remove the battery.
    Demander à FixBot
  3. Dell Inspiron 7568 Keyboard Replacement Guide, Display Assembly: étape 3, image 1 de 2 Dell Inspiron 7568 Keyboard Replacement Guide, Display Assembly: étape 3, image 2 de 2
    • Unscrew & remove the two 3mm screws (using a ph1 screwdriver bit) and the cable bracket, above the motherboard
    • Doing this will allow one to access the LCD-motherboard connector cables.
    Demander à FixBot
  4. Dell Inspiron 7568 Keyboard Replacement Guide: étape 4, image 1 de 2 Dell Inspiron 7568 Keyboard Replacement Guide: étape 4, image 2 de 2
    • Unscrew the 7mm screws that secure the left and right hinges (using a ph1 screwdriver bit).
    Demander à FixBot
  5. Dell Inspiron 7568 Keyboard Replacement Guide: étape 5, image 1 de 3 Dell Inspiron 7568 Keyboard Replacement Guide: étape 5, image 2 de 3 Dell Inspiron 7568 Keyboard Replacement Guide: étape 5, image 3 de 3
    • Disconnect the antenna cable (under the left hinge)
    • Disconnect the LCD and Touchscreen display cables under the right hinge.
    • These are a set of two cables. For better image see image two in step one of this guide.
    Demander à FixBot
  6. Dell Inspiron 7568 Keyboard Replacement Guide: étape 6, image 1 de 1
    • Carefully separate the screen from the bottom half of the device.
    Demander à FixBot
  7. Dell Inspiron 7568 Keyboard Replacement Guide, Cooling Fan: étape 7, image 1 de 2 Dell Inspiron 7568 Keyboard Replacement Guide, Cooling Fan: étape 7, image 2 de 2
    • Begin by unclipping the cable connecting the fan and the motherboard.
    • Gently separate the motherboard cable from the clamp at the bottom of the fan.
    • Remove the cable.
    Demander à FixBot
  8. Dell Inspiron 7568 Keyboard Replacement Guide: étape 8, image 1 de 2 Dell Inspiron 7568 Keyboard Replacement Guide: étape 8, image 2 de 2
    • Remove the two 3mm Phillips #1 screws that hold the fan into place.
    • Remove the fan.
    Demander à FixBot
  9. Dell Inspiron 7568 Keyboard Replacement Guide, Keyboard: étape 9, image 1 de 3 Dell Inspiron 7568 Keyboard Replacement Guide, Keyboard: étape 9, image 2 de 3 Dell Inspiron 7568 Keyboard Replacement Guide, Keyboard: étape 9, image 3 de 3
    • Once the battery, screen, cooling fan, trackpad are out, the device would resemble the one in the first picture of this step.
    • Unscrew the three screws connecting the copper pipe to the motherboard.
    • Remove the copper pipe.
    Demander à FixBot
  10. Dell Inspiron 7568 Keyboard Replacement Guide: étape 10, image 1 de 3 Dell Inspiron 7568 Keyboard Replacement Guide: étape 10, image 2 de 3 Dell Inspiron 7568 Keyboard Replacement Guide: étape 10, image 3 de 3
    • Unscrew the three 2mm wafer screws holding the motherboard.
    • Unplug the DC cable from the motherboard.
    Demander à FixBot
  11. Dell Inspiron 7568 Keyboard Replacement Guide: étape 11, image 1 de 2 Dell Inspiron 7568 Keyboard Replacement Guide: étape 11, image 2 de 2
    • Unplug the connecting strip
    Demander à FixBot
  12. Dell Inspiron 7568 Keyboard Replacement Guide: étape 12, image 1 de 3 Dell Inspiron 7568 Keyboard Replacement Guide: étape 12, image 2 de 3 Dell Inspiron 7568 Keyboard Replacement Guide: étape 12, image 3 de 3
    • Unplug the hard-drive cable
    • Remove the motherboard
    Demander à FixBot
  13. Dell Inspiron 7568 Keyboard Replacement Guide: étape 13, image 1 de 2 Dell Inspiron 7568 Keyboard Replacement Guide: étape 13, image 2 de 2
    • Unscrew the three 3mm screws holding the hard drive (using a ph1 screwdriver bit)
    • Remove the hard drive
    Demander à FixBot
  14. Dell Inspiron 7568 Keyboard Replacement Guide: étape 14, image 1 de 2 Dell Inspiron 7568 Keyboard Replacement Guide: étape 14, image 2 de 2
    • Unscrew the two 3mm screws holding the daughter board (using the ph1 screwdriver bit).
    • Set the daughterboard aside. NOTE: the daughter board doesn't have to be removed
    Demander à FixBot
  15. Dell Inspiron 7568 Keyboard Replacement Guide: étape 15, image 1 de 2 Dell Inspiron 7568 Keyboard Replacement Guide: étape 15, image 2 de 2
    • Unscrew & remove the twenty-eight 2mm bracket screws holding the keyboard bracket (using a PH000 screwdriver bit)
    • Remove the keyboard bracket
    Demander à FixBot
  16. Dell Inspiron 7568 Keyboard Replacement Guide: étape 16, image 1 de 1
    • Unscrew & remove the sixteen 2mm screws holding the keyboard (using a PH000 screwdriver bit)
    Demander à FixBot
  17. Dell Inspiron 7568 Keyboard Replacement Guide: étape 17, image 1 de 3 Dell Inspiron 7568 Keyboard Replacement Guide: étape 17, image 2 de 3 Dell Inspiron 7568 Keyboard Replacement Guide: étape 17, image 3 de 3
    • Unplug the keyboard ("KB") and backlight ("BL") cable
    • Remove the keyboard.
    Demander à FixBot
2 autres ont terminé cette réparation.
Luis Velez
Membre depuis le 02/19/17
452 Réputation
2 tutoriels rédigés
Équipe
USF Tampa, Team S2-G2, Lacy Spring 2017 Membre de l'équipe USF Tampa, Team S2-G2, Lacy Spring 2017
USFT-LACY-S17S2G2
4 membres
7 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 5
30 derniers jours : 26
Total : 1,346
