Introduction
When removing or replacing the mother board of the Dell Inspiron 7568 it is important to make sure the laptop it is unplugged and completely turned off. User should also remember to be careful when unplugging and removing the battery. It is recommended that users keep different screw types separated to keep assembly easier. Make sure to uses a Phillips head #1 screw driver. Make sure to work in a static free area with static protection gloves.
Ce dont vous avez besoin
Remove the ten 7mm Phillips #1 screws on the bottom cover.
Remove the bottom cover.
Begin by unclipping the cable connecting the fan and the motherboard.
Gently separate the motherboard cable from the clamp at the bottom of the fan.
Remove the cable.
Remove six 3mm Phillips #1 screws to fully remove the motherboard.
Disconnect the various connection points from the motherboard to the laptop.
Remove the motherboard.
