Aller au contenu principal
Dell Inspiron 7568 Motherboard Replacement
Ce dont vous avez besoin
  1. Dell Inspiron 7568 Motherboard Replacement, Battery: étape 1, image 1 de 2 Dell Inspiron 7568 Motherboard Replacement, Battery: étape 1, image 2 de 2
    • Remove the ten 7mm Phillips #1 screws on the bottom cover.
    • Remove the bottom cover.
  2. Dell Inspiron 7568 Motherboard Replacement: étape 2, image 1 de 2 Dell Inspiron 7568 Motherboard Replacement: étape 2, image 2 de 2
    • Remove the four 3mm Phillips #1 screws holding the battery.
    • Unhinge the connector cable to the battery.
    • Remove the battery.
  3. Dell Inspiron 7568 Motherboard Replacement, RAM: étape 3, image 1 de 1
    • Release the RAM by unhinging the connecting bars outward.
  4. Dell Inspiron 7568 Motherboard Replacement: étape 4, image 1 de 2 Dell Inspiron 7568 Motherboard Replacement: étape 4, image 2 de 2
    • Remove the RAM.
  5. Dell Inspiron 7568 Motherboard Replacement, Cooling Fan: étape 5, image 1 de 2 Dell Inspiron 7568 Motherboard Replacement, Cooling Fan: étape 5, image 2 de 2
    • Begin by unclipping the cable connecting the fan and the motherboard.
    • Gently separate the motherboard cable from the clamp at the bottom of the fan.
    • Remove the cable.
  6. Dell Inspiron 7568 Motherboard Replacement: étape 6, image 1 de 2 Dell Inspiron 7568 Motherboard Replacement: étape 6, image 2 de 2
    • Remove the two 3mm Phillips #1 screws that hold the fan into place.
    • Remove the fan.
  7. Dell Inspiron 7568 Motherboard Replacement, Motherboard: étape 7, image 1 de 2 Dell Inspiron 7568 Motherboard Replacement, Motherboard: étape 7, image 2 de 2
    • Remove six 3mm Phillips #1 screws to fully remove the motherboard.
    • Disconnect the various connection points from the motherboard to the laptop.
    • Remove the motherboard.
Elijah Basile
Membre depuis le 11/06/19
358 Réputation
4 tutoriels rédigés
Équipe
IUPUI, Team S1-G4, Stella Fall 2019 Membre de l'équipe IUPUI, Team S1-G4, Stella Fall 2019
IUPUI-STELLA-F19S1G4
4 membres
4 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 5
30 derniers jours : 5
Total : 317
