Aller au contenu principal
Dell Inspiron 7573 2-in-1 Battery Replacement
Ce dont vous avez besoin
  1. Dell Inspiron 7573 2-in-1 Battery Replacement, Battery: étape 1, image 1 de 2 Dell Inspiron 7573 2-in-1 Battery Replacement, Battery: étape 1, image 2 de 2
    • Make sure computer is off before you begin.
    • Remove the four 5 mm screws from the bottom edge of the laptop using a Phillips #00 screwdriver.
    • Loosen the remaining six captive screws from the bottom cover with a Phillips #00 screwdriver.
  2. Dell Inspiron 7573 2-in-1 Battery Replacement: étape 2, image 1 de 3 Dell Inspiron 7573 2-in-1 Battery Replacement: étape 2, image 2 de 3 Dell Inspiron 7573 2-in-1 Battery Replacement: étape 2, image 3 de 3
    • Using a spudger, pry off the bottom cover by gently prying from corner to corner in order to disengage the plastic clips.
    • Lift off the bottom cover.
    • After the base cover is removed, your laptop should look similar as depicted in the images provided.
  3. Dell Inspiron 7573 2-in-1 Battery Replacement: étape 3, image 1 de 1
    • Remove the four 3 mm screws holding the battery in place with a Phillips #00 screwdriver.
  4. Dell Inspiron 7573 2-in-1 Battery Replacement: étape 4, image 1 de 3 Dell Inspiron 7573 2-in-1 Battery Replacement: étape 4, image 2 de 3 Dell Inspiron 7573 2-in-1 Battery Replacement: étape 4, image 3 de 3
    • Using the pull tab, disconnect the battery cable from the system board.
    • Lift the battery out from the laptop case.
Kylie Freese
Membre depuis le 09/27/21
405 Réputation
3 tutoriels rédigés
Équipe
Casper College, Team 1-2, Lareau Fall 2021 Membre de l'équipe Casper College, Team 1-2, Lareau Fall 2021
CASC-LAREAU-F21S1G2
3 membres
4 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 25
30 derniers jours : 55
Total : 2,305
