Aller au contenu principal
Dell Inspiron 7573 2-in-1 Hard Drive Replacement
Ce dont vous avez besoin
  1. Dell Inspiron 7573 2-in-1 Hard Drive Replacement, Battery: étape 1, image 1 de 2 Dell Inspiron 7573 2-in-1 Hard Drive Replacement, Battery: étape 1, image 2 de 2
    • Make sure computer is off before you begin.
    • Remove the four 5 mm screws from the bottom edge of the laptop using a Phillips #00 screwdriver.
    • Loosen the remaining six captive screws from the bottom cover with a Phillips #00 screwdriver.
  2. Dell Inspiron 7573 2-in-1 Hard Drive Replacement: étape 2, image 1 de 3 Dell Inspiron 7573 2-in-1 Hard Drive Replacement: étape 2, image 2 de 3 Dell Inspiron 7573 2-in-1 Hard Drive Replacement: étape 2, image 3 de 3
    • Using a spudger, pry off the bottom cover by gently prying from corner to corner in order to disengage the plastic clips.
    • Lift off the bottom cover.
    • After the base cover is removed, your laptop should look similar as depicted in the images provided.
  3. Dell Inspiron 7573 2-in-1 Hard Drive Replacement: étape 3, image 1 de 1
    • Remove the four 3 mm screws holding the battery in place with a Phillips #00 screwdriver.
  4. Dell Inspiron 7573 2-in-1 Hard Drive Replacement: étape 4, image 1 de 3 Dell Inspiron 7573 2-in-1 Hard Drive Replacement: étape 4, image 2 de 3 Dell Inspiron 7573 2-in-1 Hard Drive Replacement: étape 4, image 3 de 3
    • Using the pull tab, disconnect the battery cable from the system board.
    • Lift the battery out from the laptop case.
  5. Dell Inspiron 7573 2-in-1 Hard Drive Replacement, Hard Drive: étape 5, image 1 de 3 Dell Inspiron 7573 2-in-1 Hard Drive Replacement, Hard Drive: étape 5, image 2 de 3 Dell Inspiron 7573 2-in-1 Hard Drive Replacement, Hard Drive: étape 5, image 3 de 3
    • Using the pull-tab, disconnect the hard drive cable from the motherboard.
    • In a laptop containing a hard drive, the other end of the cable will be seated in the hard drive under the silver cover. The device used in this guide was lacking one, so the cable appears loose.
  6. Dell Inspiron 7573 2-in-1 Hard Drive Replacement: étape 6, image 1 de 1
    • Remove the three 3 mm screws that secure the hard-drive assembly using a Phillips #00 screwdriver.
  7. Dell Inspiron 7573 2-in-1 Hard Drive Replacement: étape 7, image 1 de 1
    • Disconnect the hard drive cable from the hard drive.
  8. Dell Inspiron 7573 2-in-1 Hard Drive Replacement: étape 8, image 1 de 2 Dell Inspiron 7573 2-in-1 Hard Drive Replacement: étape 8, image 2 de 2
    • Lift the right speaker by releasing the rubber grommets from the slots on the palm-rest assembly.
  9. Dell Inspiron 7573 2-in-1 Hard Drive Replacement: étape 9, image 1 de 1
    • Remove the four 3 mm screws that secure the hard drive bracket to the hard drive with a Phillips #00 screwdriver.
  10. Dell Inspiron 7573 2-in-1 Hard Drive Replacement: étape 10, image 1 de 1
    • Lift up the hard drive and replace it.
Kylie Freese
Membre depuis le 09/27/21
453 Réputation
3 tutoriels rédigés
Équipe
Casper College, Team 1-2, Lareau Fall 2021 Membre de l'équipe Casper College, Team 1-2, Lareau Fall 2021
CASC-LAREAU-F21S1G2
3 membres
4 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 11
30 derniers jours : 27
Total : 1,214
