Aller au contenu principal
Dell Inspiron 7590 Battery Replacement
Ce dont vous avez besoin
  1. Dell Inspiron 7590 Battery Replacement, Battery: étape 1, image 1 de 2 Dell Inspiron 7590 Battery Replacement, Battery: étape 1, image 2 de 2
    • Use a Phillips #000 screwdriver to remove seven screws securing the base face of your device.
    • Unscrew the remaining two screws in the corners closest to the bottom of the base of the laptop.
  2. Dell Inspiron 7590 Battery Replacement: étape 2, image 1 de 3 Dell Inspiron 7590 Battery Replacement: étape 2, image 2 de 3 Dell Inspiron 7590 Battery Replacement: étape 2, image 3 de 3
    • Using a Jimmy, work your way around the edge of the back panel and the side of the laptop to remove the back panel.
    • Separate the remainder of the paneling using an Opening Pick.
    • Avoid using a metal utensil when separating the remainder of the paneling to avoid paint chipping.
  3. Dell Inspiron 7590 Battery Replacement: étape 3, image 1 de 3 Dell Inspiron 7590 Battery Replacement: étape 3, image 2 de 3 Dell Inspiron 7590 Battery Replacement: étape 3, image 3 de 3
    • Using a Phillips #0 screwdriver, remove the three screws securing the battery.
  4. Dell Inspiron 7590 Battery Replacement: étape 4, image 1 de 2 Dell Inspiron 7590 Battery Replacement: étape 4, image 2 de 2
    Outil utilisé dans cette étape :
    • Using a pair of tweezers, disconnect the ribbon cable connecting the battery to the motherboard.
  5. Dell Inspiron 7590 Battery Replacement: étape 5, image 1 de 2 Dell Inspiron 7590 Battery Replacement: étape 5, image 2 de 2
    • Remove the battery from the device.
2 autres ont terminé cette réparation.
Danielle Byrd
Membre depuis le 02/13/20
145 Réputation
1 tutoriel rédigé
Un commentaire
Hello,
I noticed in your tear down there are two ram slots. I tried to find this information online, but was unable to. Are any of those ram slots an empty slot, to possibly upgrade?
Dave Szes - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 22
30 derniers jours : 29
Total : 1,676
