Introduction
If you need to replace the keyboard of your Dell Inspiron 8600, follow this guide.
Outils
Pièces
Aucune pièce spécifiée.
Insert a spudger into the notch at the far left side of the top blue panel and pry the hinge cover off.
You may need to pry the other side off as well. You can do this by inserting the spudger between the hinge and the top cover.
Using the Phillips #1 remove the screws at the top of the keyboard as indicated.
You will need to pull out the white tab underneath the keyboard upwards until it pops out of its socket.
2 autres ont terminé cette réparation.
Un commentaire
followed instructions, keyboard works great now!! All letters and numbers work! Thank you
