Aller au contenu principal
Dell Inspiron 8600 Keyboard Replacement
Ce dont vous avez besoin
  1. Dell Inspiron 8600 Keyboard Replacement, Battery: étape 1, image 1 de 1
    • Remove the battery from the bottom left of the laptop as shown.
    • Remove the battery before operating on the computer to avoid electrocution.
  2. Dell Inspiron 8600 Keyboard Replacement, Hinge Cover: étape 2, image 1 de 3 Dell Inspiron 8600 Keyboard Replacement, Hinge Cover: étape 2, image 2 de 3 Dell Inspiron 8600 Keyboard Replacement, Hinge Cover: étape 2, image 3 de 3
    • Insert a spudger into the notch at the far left side of the top blue panel and pry the hinge cover off.
    • You may need to pry the other side off as well. You can do this by inserting the spudger between the hinge and the top cover.
    • Be careful of the wire attached to the underside of the hinge cover.
  3. Dell Inspiron 8600 Keyboard Replacement: étape 3, image 1 de 1
    • Pull the small black tab on the right hand side of the laptop.
    • You have now removed the hinge cover.
  4. Dell Inspiron 8600 Keyboard Replacement, Keyboard: étape 4, image 1 de 3 Dell Inspiron 8600 Keyboard Replacement, Keyboard: étape 4, image 2 de 3 Dell Inspiron 8600 Keyboard Replacement, Keyboard: étape 4, image 3 de 3
    • Using the Phillips #1 remove the screws at the top of the keyboard as indicated.
    • Do not just lift up. There is a tab underneath the keyboard that is still connected to the mother board.
    • You will need to pull out the white tab underneath the keyboard upwards until it pops out of its socket.
    • The keyboard should be easily removable at this point.
2 autres ont terminé cette réparation.
Perry
Membre depuis le 04/12/11
251 Réputation
4 tutoriels rédigés
Équipe
Cal Poly, Team 18-22, Garner Spring 2011 Membre de l'équipe Cal Poly, Team 18-22, Garner Spring 2011
CPSU-GARNER-S11S18G22
4 membres
16 tutoriels rédigés
Un commentaire
followed instructions, keyboard works great now!! All letters and numbers work! Thank you
fordsmtack - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 3
Total : 3,859
