Aller au contenu principal
Introduction
Follow this guide to replace the top case of the Dell Inspiron 8600.
Pièces
Aucune pièce spécifiée.
  1. Dell Inspiron 8600 Top Case Replacement, Battery: étape 1, image 1 de 1
    • Remove the battery from the bottom of the laptop.
    • Please click on the following link for further instruction on how to remove the battery. Dell Inspiron 9100 Battery Replacement
    • It is important to remove the battery so that you will not be electrocuted while working with the computer's hardware.
  2. Dell Inspiron 8600 Top Case Replacement, Power Button: étape 2, image 1 de 3 Dell Inspiron 8600 Top Case Replacement, Power Button: étape 2, image 2 de 3 Dell Inspiron 8600 Top Case Replacement, Power Button: étape 2, image 3 de 3
    • Locate the small opening at the upper left of the top blue panel which houses the power button.
    • Use a spudger to lift up and remove the blue panel.
    • Caution: The hinge cover is still connected to the interior of the computer by a small black tab.
  3. Dell Inspiron 8600 Top Case Replacement: étape 3, image 1 de 1
    • Locate the black tab at the upper right corner of the keyboard, and gently pull the black tab to the left to disconnect the hinge cover.
    • You should now be able to completely remove the hinge cover.
  4. Dell Inspiron 8600 Top Case Replacement, Display Module: étape 4, image 1 de 2 Dell Inspiron 8600 Top Case Replacement, Display Module: étape 4, image 2 de 2
    • Flip the laptop over and remove the indicated screws.
    • Flip the laptop back over.
    • Find the two places where the display module is attached to the base of the computer.
  5. Dell Inspiron 8600 Top Case Replacement: étape 5, image 1 de 1
    • Disconnect the video card from the display module by gently lifting upwards on the black tab.
  6. Dell Inspiron 8600 Top Case Replacement: étape 6, image 1 de 2 Dell Inspiron 8600 Top Case Replacement: étape 6, image 2 de 2
    • Lift the display module directly upwards from the base of the computer.
  7. Dell Inspiron 8600 Top Case Replacement: étape 7, image 1 de 1
    • Now remove the display module.
  8. Dell Inspiron 8600 Top Case Replacement, Top Case: étape 8, image 1 de 3 Dell Inspiron 8600 Top Case Replacement, Top Case: étape 8, image 2 de 3 Dell Inspiron 8600 Top Case Replacement, Top Case: étape 8, image 3 de 3
    • First, remove all tabs using a flat head/ finger.
    • Next, remove all screws using a #1 Philips screwdriver.
    • Pull apart top case from the lower case. It will be quite difficult to separate.
  9. Dell Inspiron 8600 Top Case Replacement: étape 9, image 1 de 3 Dell Inspiron 8600 Top Case Replacement: étape 9, image 2 de 3 Dell Inspiron 8600 Top Case Replacement: étape 9, image 3 de 3
    • Remove all screws on the top of the lcd
    • There all several screw on each side of the LCD. Remove all.
  10. Dell Inspiron 8600 Top Case Replacement: étape 10, image 1 de 1
    • LCD should remove smoothly.
    • The top case will be what remains.
Perry
Membre depuis le 12/04/2011
251 Réputation
4 tutoriels rédigés
Équipe
Cal Poly, Team 18-22, Garner Spring 2011 Membre de l'équipe Cal Poly, Team 18-22, Garner Spring 2011
CPSU-GARNER-S11S18G22
4 membres
16 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 4
Total : 2,093
