Aller au contenu principal
Dell Inspiron 910 RAM Replacement
Ce dont vous avez besoin
  1. Dell Inspiron 910 RAM Replacement, Battery: étape 1, image 1 de 1
    • Flip the laptop so the battery is facing upwards.
    • Push the battery release tabs toward the center of the device.
    • Remove the battery.
  2. Dell Inspiron 910 RAM Replacement, Preparation: étape 2, image 1 de 1
    • Remember to power off the device before starting!
    • Disconnect any cables or external devices from the laptop, then flip it and remove the battery by pressing the battery tabs inward.
  3. Dell Inspiron 910 RAM Replacement: étape 3, image 1 de 1
    • Locate the large black panel with two screws holding it in place. (This is the panel with ventilation holes)
    • Unscrew both of the screws using a Philips Screwdriver.
  4. Dell Inspiron 910 RAM Replacement: étape 4, image 1 de 1
    • Remove the panel by pulling upward.
    • Removal may require some force!
  5. Dell Inspiron 910 RAM Replacement: étape 5, image 1 de 2 Dell Inspiron 910 RAM Replacement: étape 5, image 2 de 2
    • After removing the panel, locate the memory modules.
    • Look for the silver tabs on either side of the white plastic holding the RAM in place. Then gently remove the RAM.
  6. Dell Inspiron 910 RAM Replacement, For Reinstallation: étape 6, image 1 de 1
    • Depress the RAM until it locks into place; there should be an audible clicking noise when it does so and the gold contacts should be barely visible.
    • Congratulations! You have completed the guide.
4 autres ont terminé cette réparation.
Kyle Beekman
Membre depuis le 04/05/12
144 Réputation
6 tutoriels rédigés
Équipe
Cal Poly, Team 14-10, Forte Spring 2012 Membre de l'équipe Cal Poly, Team 14-10, Forte Spring 2012
CPSU-FORTE-S12S14G10
5 membres
7 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 11
30 derniers jours : 11
Total : 2,935
