1. Locate the release tabs located on either side of the battery, on the bottom of the laptop
    • Locate the release tabs located on either side of the battery, on the bottom of the laptop
    • Push the release tabs toward the center of the device.
    • Remove the battery.
  2. Remove the two countersunk keyboard screws using the Phillips #00 screwdriver
    • Remove the two countersunk keyboard screws using the Phillips #00 screwdriver
    • Battery removal is not necessary for keyboard removal.
    • Lift up the keyboard using your fingers or a plastic opening tool
    • Do not not tear the ribbon cable hidden behind the keyboard
    • Disconnect the cable by sliding the connector ears outward
    • After removing the keyboard, use the plastic opening tools or other form of leverage to remove the rest of the silver casing
    • Depending on your model, there could still be some hidden screws on the bottom case of the laptop that hold the palm-rest in place.
    • Use a plastic opening tool to pry the silver portion front of the top away from the colored portion.
    • There should be two small screws to the bottom corners of the speaker assembly, which can be found below the screen. Unscrew them.
    • NOTE: Keep track of where you put the screws after you remove them. Keep screws of the same size together and away from screws of different sizes.
    • There should be a cable coming off the speakers that connects to the base below the keyboard. It should easily slide out from here. Congratulations! You have successfully removed the speakers.
3 autre(s) ont terminé cette réparation.
Kyle Beekman
Membre depuis le 05/04/2012
144 Réputation
6 tutoriels rédigés
Équipe
Cal Poly, Team 14-10, Forte Spring 2012 Membre de l'équipe Cal Poly, Team 14-10, Forte Spring 2012
CPSU-FORTE-S12S14G10
5 membres
7 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 8
Total : 1,230
