Aller au contenu principal
Dell Inspiron 910 Touchpad Buttons Replacement
Ce dont vous avez besoin
  1. Dell Inspiron 910 Touchpad Buttons Replacement, Battery: étape 1, image 1 de 1
    • Flip the laptop so the battery is facing upwards.
    • Push the battery release tabs toward the center of the device.
    • Remove the battery.
  2. Dell Inspiron 910 Touchpad Buttons Replacement, Keyboard: étape 2, image 1 de 1
    • Remove the two countersunk keyboard screws using the Phillips #00 screwdriver.
  3. Dell Inspiron 910 Touchpad Buttons Replacement: étape 3, image 1 de 1
    • Lift up the keyboard using your fingers or a plastic opening tool.
    • Potential for device damage: Do not tear the ribbon cable hidden behind the keyboard.
    • Disconnect the cable by sliding the connector ears outward.
  4. Dell Inspiron 910 Touchpad Buttons Replacement, Touchpad Buttons: étape 4, image 1 de 1
    • Remove the seven Phillips #00 screws that hold the metal component to the frame
    • Detach the two ribbon cables on either side of the silver panel
    • Be careful to not tear the ribbon cables hidden behind the panel
    • Gently lift the silver panel from the laptop using the plastic opening tool
    • Set the laptop aside
    • depending on your model, there could still be some hidden screws on the bottom of the case of the mini that hold the palm-rest in place
  5. Dell Inspiron 910 Touchpad Buttons Replacement: étape 5, image 1 de 1
    • Flip the silver panel over
    • Remove the four screws that connect the buttons to the panel using the Phillips #00 Screwdriver
  6. Dell Inspiron 910 Touchpad Buttons Replacement: étape 6, image 1 de 1
    • Remove the covers from the panel
    • Remove the buttons from the panel
    • Release the mouse button by flipping the center connector tab up
Kyle Beekman
Membre depuis le 04/05/12
144 Réputation
6 tutoriels rédigés
Équipe
Cal Poly, Team 14-10, Forte Spring 2012 Membre de l'équipe Cal Poly, Team 14-10, Forte Spring 2012
CPSU-FORTE-S12S14G10
5 membres
7 tutoriels rédigés
0 Guide Comments
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 21
Total : 2,238
