Introduction
This guide requires a Phillips #00 screwdriver
Pièces
Aucune pièce nécessaire.
Unplug the laptop from the power adapter and turn the power off.
  • Unplug the laptop from the power adapter and turn the power off.
  • Failure to unplug laptop before proceeding could result in risk of electric shock!
Ajouter un commentaire
Slide the battery-lock tab and hold.
  • Slide the battery-lock tab and hold.
  • Flip the battery away from the chassis to remove it.
  • Undo the screw on the Mini-PCI card cover labeled "C"
  • This screw will remain within the panel
  • Remove the panel from the chassis.
  • Disconnect the antenna cables from the Mini-PCI card.
  • Use your fingertips to carefully spread apart the white plastic tabs.
  • Flip the Mini-PCI card up at a 45 degree angle.
  • Remove the card from the computer by sliding out diagonally
  • Ground yourself while dealing with the card. Static shock can cause damage to the card. Store the card in anti-static bag when not in use.
charlierefvem
Membre depuis le 11/01/2011
854 Réputation
7 tutoriels rédigés
Équipe
Cal Poly, Team 13-2, Forte Winter 2011 Membre de l'équipe Cal Poly, Team 13-2, Forte Winter 2011
CPSU-FORTE-W11S13G2
5 membres
8 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 3
Total : 3,974
