Aller au contenu principal
Dell Inspiron 9300 WIFI Card Replacement
Ce dont vous avez besoin
  1. Dell Inspiron 9300 WIFI Card Replacement, Modem & WIFI Card Prerequisite: étape 1, image 1 de 3 Dell Inspiron 9300 WIFI Card Replacement, Modem & WIFI Card Prerequisite: étape 1, image 2 de 3 Dell Inspiron 9300 WIFI Card Replacement, Modem & WIFI Card Prerequisite: étape 1, image 3 de 3
    Outil utilisé dans cette étape :
    Anti-Static Wrist Strap
    $7.95
    J'achète
    • Flip the computer over and place it on a clean level surface.
    • Loosen the screws using a size #0 Phillips screwdriver.
    • The screws do not come completely out.
    • It is strongly recommended that the Anti-Static Wrist Strap is used to avoid damage to internal components.
  2. Dell Inspiron 9300 WIFI Card Replacement: étape 2, image 1 de 2 Dell Inspiron 9300 WIFI Card Replacement: étape 2, image 2 de 2
    • Once the screws are loose, open the panel using a plastic opening tool to access the components below.
    • The modem card should be labeled MODEM. The WIFI card is larger than the modem and closer to the outer edge of the computer.
  3. Dell Inspiron 9300 WIFI Card Replacement, WIFI Card: étape 3, image 1 de 2 Dell Inspiron 9300 WIFI Card Replacement, WIFI Card: étape 3, image 2 de 2
    • Gently pry up on the gold antennae connections using a spudger.
    • Gently pry open both retaining clips on either side of the WiFi card using a spudger.
    • Once the clips are open and the card is unplugged, it is safe to remove.
Randy McMillan
Membre depuis le 09/21/16
738 Réputation
4 tutoriels rédigés
Équipe
Master Techs Membre de l'équipe Master Techs
Community
321 membres
1 516 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 1
30 derniers jours : 13
Total : 434
